Sponsored by: Real Truck
hub removal
Old Jul 17, 2011 | 08:35 AM
jawdoc's Avatar
jawdoc
hub removal
The axle is out and now I have to remove the hub (which has the lug bolts for the wheel).
With the axle out inside looks like a corrugated ring nut on a threaded sleeve.
Do I loosen this to slide the hub off?
Old Jul 17, 2011 | 10:50 AM
jawdoc's Avatar
jawdoc
heres a pic
Old Jul 17, 2011 | 12:08 PM
Rongold's Avatar
Rongold
HUB REMOVAL
What you see is the wheel bearing adjusting nut. Remove it, and the hub will slide off. If you're doing this to replace the emergency brake shoes, it is not necessary---the shoes will come off with the hub in place.
RON
Old Jul 17, 2011 | 12:55 PM
jawdoc's Avatar
jawdoc
Ron youre the best!
It worked great.
I have to replace the entire E-brake housing - upstate NY salt rust.
Old Jul 18, 2011 | 10:18 AM
jawdoc's Avatar
jawdoc
Everything is put back together
Now because I took the cover off the diff I need to refull it with gear oil.
What do I use to remove the filler bolt? Its an internal square design.
Old Jul 18, 2011 | 11:28 AM
northwindone's Avatar
northwindone
You just use a 3/8" drive ratchet to remove that plug. When I did my Nissan (which has the same type of plug) I found it easier to use a short extension though to put a little knuckle room between the drive ratchet and the diff, which might not be necessary on the Ford. Just be sure to use a little bit of thread sealant on the plug before you put it back in, just be careful not to get any in the case.
jawdoc
Jun 20, 2014 06:17 AM
hawgystyle
Dec 9, 2012 06:59 PM
MattL09
Sep 9, 2009 09:40 PM
freightdogfred
15
Dec 17, 2008 10:07 AM
HaWiiLuVeR
Aug 14, 2003 06:54 PM
