Sponsored by: Real Truck
Trans temp gauge doesn't move
Old Jul 17, 2011 | 11:46 AM
AC-MAN's Avatar
AC-MAN
I have a 2002 F250 with diesel and auto. The trans temp gauge never moves cold or hot it reads halfway up normal. Is there an easy way to see if it is the gauge or sender?
Old Jul 17, 2011 | 12:06 PM
Hotpocket's Avatar
Hotpocket
my 04 is the same way no matter how hard i work it
Old Jul 17, 2011 | 01:39 PM
jh818's Avatar
jh818
The gauge typically doesn't move until it reaches 230F I believe. When it does move, it moves up rather quickly, so be prepared to pull over once you see it nudge upwards.
I would get a ScangaugeII to monitor it. I know the earlier diesel trans oil cooler (prior to 6.0L) has the smallest one out of all the engines available.
When it is colder out (winter time), the gauge would be down low when you first start it.
Old Jul 17, 2011 | 02:24 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Ford's coolant and tranny gauges are nothing more than idiot light gauges.....get the above suggested Scan Gauge II or a set of analog gauges.
Old Jul 18, 2011 | 09:51 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The transmission temp gauge will sit right in the middle anytime the trans is between 50°F and 230°F. There is nothing to fix here, if you want more specific readings you need an aftermarket gauge.
Old Jul 18, 2011 | 11:29 AM
RUNVS's Avatar
RUNVS
I have yet to tow since I put in my Auto Gage but I thought it wasn't working b/c it would barely move. It will "spring" into position when I start the truck so I know the gauge was getting power.
While trying to work out my false overheat I was putting the truck through a "stress" test and noticed the gauge moved but never past 150 deg. Like others here I recommend an aftermarket. But I wouldn't stop at the Trans. Temp. I also have an Oil Pressure and Water Temp. all in a 3-gauge a-pillar pod and there is LOTS of help on here how to install one of those!!
kx125str99
19
Dec 20, 2016 07:51 PM
finallyo3gt
18
Jul 16, 2016 08:47 PM
Roofman1515
Jul 9, 2016 10:36 PM
Haywire-Powerstroke
May 10, 2016 10:12 AM
1L243
19
Apr 5, 2011 07:16 AM
