Front suspension swap
Old Jul 17, 2011 | 05:43 AM
RJK2's Avatar
RJK2
Resurrecting an '83 F100.
Have a '94 donor.
Will the '94 front suspension (I-beams, etc) fit the '83?
If not, what about the springs?
PO had heated the '83 springs in an attempt to lower it, poorly done.
Figure the '94 F150 susp. components would be heavier duty.
__________________________________________________ _________
1999 E320 (mine but daughter has it)
1994 F150 #1 (hurt)
1994 F150 #2 (parts)
1989 560 SL (wife's DD)
1986 560 SL (deceased)
1988 300 TE (departed)
1994 945T (daughter's but I have it)
1988 244DL (it lives!)
1986 242Ti (fallow)
1968 GT500KR (under restoration)
1941 Luxury Liner (son's project)
Old Jul 17, 2011 | 11:51 AM
83capril's Avatar
83capril
From what I have gathered it should be a direct swap. 1980 thro 1996 are the same. Another thing is maybe swap out rear springs if the donor truck is 4x2. I know my 80 F100 has light duty springs.
Old Jul 17, 2011 | 04:38 PM
dustybumpers's Avatar
dustybumpers
Some of the earlier trucks had stamped I beams. There may be some differances, but if you have the whole truck for parts, you can make it work.
Old Jul 17, 2011 | 08:34 PM
RJK2's Avatar
RJK2
Yeah, the '83 has the stamped version & I thought the '94 looked to be stronger.
Can't do the rears though, damaged in the t-bone.
Old Jul 17, 2011 | 08:40 PM
dustybumpers
83 has the 9", you'll want to keep that
Old Jul 17, 2011 | 08:45 PM
Franklin2's Avatar
Franklin2
If the donor frontend had a different gear ratio than the original 9 inch, and the donor had a good 8.8 that of course would match the frontend, the 8.8 would go in if it were my project. The 8.8 has a pretty good track record.
Old Jul 17, 2011 | 08:48 PM
dustybumpers
I think it's a 2x4 Dave, but your right, it would be worth finding another 8.8 in the junk yard if the truck is a 4x4
Old Jul 17, 2011 | 10:51 PM
RJK2's Avatar
RJK2
Its a 2X4, I was referring to the rear springs mentioned in an earlier post. Sorry I was unclear.
unleashd
Dec 18, 2016 11:48 AM
Tom
2015 - 2020 F150
26
Jun 18, 2016 01:54 PM
19mfn96
48
Feb 14, 2012 10:19 PM
Brutl_Force
1997 - 2003 F150
Nov 28, 2011 08:57 PM
OGTerror
Offroad & 4x4
17
Sep 30, 2009 11:23 PM
