EGR Cleaning ?
Old Jul 15, 2011 | 07:43 PM
pile_53574's Avatar
pile_53574
Question EGR Cleaning ?
I Have cleaned my EGR Valve on the last two oil changes ( about fifth time doing it). How are u guys cleaning out all the crud from the intake?? I've used the shop vac to get as much as I can out. Can/Should I use that sea foam deep creep or would that a big NO NO?? Not sure if that would screw anything else up?? Where would all the crud go??? Thanks Oops its an 06 with 80,000 mi
Old Jul 15, 2011 | 08:46 PM
wulfman's Avatar
wulfman
I would just leave it alone and keep the valve clean, you can get it when you go in to do the oil cooler when that time comes.
Old Jul 15, 2011 | 09:25 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Good scrub brush and the shop vac. I really don't think you can do much else, short of pulling the intake out and having it cleaned.
Old Jul 16, 2011 | 11:27 AM
JESTERxHEAD's Avatar
JESTERxHEAD
I wouldnt put the deep creep stuff in the intake....its possible to have the motor run away from you if enough fuel (deep creep) is in there. works in gasoline land but diesels would be a bit dangerous.
02GrayPowerStroke
Mar 9, 2015 08:25 PM
eriklane
Dec 1, 2012 07:05 PM
gearloose1
Apr 22, 2010 09:09 AM
bhtx
Mar 17, 2009 02:14 PM
happymonster
1997 - 2003 F150
Feb 4, 2005 02:46 PM
