Sponsored by: Real Truck
power issue
Old Jul 15, 2011 | 05:42 PM
joeyf250's Avatar
joeyf250
power issue
My 1999 f250 has a 5.4l when I am going up a steep hill or towing my truck seems to loose power between 2200-2600 rpm in third gear it's an automatic I did an trans service replaced two coil packs and the EGR sensor the truck has 153000 miles I just bought it in may and did the intake gasket put new plugs in. put it on the dealer computer and can't find anything wrong anybody have any ideas?
Old Jul 15, 2011 | 11:05 PM
jd1083's Avatar
jd1083
Have you had the catalytic converter checked? My buddy had a similar issue with his 5.4 and it ended up being a partially clogged cat.
Old Jul 16, 2011 | 08:44 AM
BareBones's Avatar
BareBones
What make of plugs did you use?
Old Jul 18, 2011 | 07:21 PM
joeyf250's Avatar
joeyf250
Motorcraft plugs I will check the cat but it doesn't' do it unless I'm going up a big hill and really get on the gas or I'm towing a trailer
Old Jul 18, 2011 | 08:21 PM
99f350sd's Avatar
99f350sd
When it down shifts does it scream? Or does it downshift? These engines don't have much power unless they shift down and get the r's up. Esp a 99. If you go up a hill in 2nd gear if you floor it will it go to 5k rpm quickly? If not you may have clogged fuel filter or bad pump..
Dick
Old Jul 19, 2011 | 01:32 AM
joeyf250's Avatar
joeyf250
It shifts ok just when your on the gas it feels like it has a lot of power then no power then lots of power and the cycle keeps repeating until it hits 2800 rpm
Old Jul 19, 2011 | 08:04 AM
99f350sd's Avatar
99f350sd
Does the power stay low after 2800?
Old Jul 19, 2011 | 04:19 PM
joeyf250's Avatar
joeyf250
No the power picks up like it should
Old Jul 19, 2011 | 05:37 PM
99f350sd's Avatar
99f350sd
On the 99's there is a power valve in the intake..System that operates at a certain rpm..
Old Jul 19, 2011 | 08:46 PM
joeyf250's Avatar
joeyf250
I just did an intake gaskit never noticed the problem before I did it where in the intake is this power valve ?
Old Jul 19, 2011 | 08:52 PM
99f350sd's Avatar
99f350sd
Don't really know. Only in the 99's and maybe there is a cut off date..They stopped putting it in there in 2000. I guess it wasn't such a good idea..Supposed to help with low rpm power and at a certain rpm open up the whole intake to the engine. Maybe its not hooked up?
Dick
Old Jul 19, 2011 | 08:55 PM
joeyf250's Avatar
joeyf250
I'll have to check into it thanks for the info
Old Jul 19, 2011 | 08:58 PM
99f350sd's Avatar
99f350sd
I have all the info on cd I'll have to look at it again..Most folks don't know about it..
Old Jul 20, 2011 | 08:34 PM
joeyf250's Avatar
joeyf250
Let me know my brother inlaw is a Ford mechanic and he doesn't remember
1990-f250
Jul 20, 2014 09:18 AM
74fordhighboy
May 20, 2010 01:25 PM
lowboy250
Apr 8, 2010 08:42 PM
tscryba
1997 - 2003 F150
Nov 10, 2004 12:09 AM
dlj31
Modular V10 (6.8l)
82
Jul 15, 2004 09:23 PM
