Sponsored by: Real Truck
pcm reset?
Old Jul 14, 2011 | 08:22 PM
Edkajo's Avatar
Edkajo
pcm reset?
03 f350 7.3L
I pulled the PCM keep alive fuse by mistake while checking the instrument cluster fuse. The truck started for a second after that then died. When the key is turned there's random clicking, cd appears to go through a cycle, guages hop, drop then the truck appears to have no electrical power. Would pulling that fuse cause this? If so is there a reset process? Any input would be helpful. thanks
Old Jul 14, 2011 | 08:47 PM
Pocket's Avatar
Pocket
Disconnecting the batteries is the same thing as pulling that fuse.
In other words, it's not the PCM.
Old Jul 15, 2011 | 05:27 AM
Edkajo's Avatar
Edkajo
Thanks.
Any suggestions on what happened?
Truck's been having some issues with the interior lights/ radio working right but other than that it was fine prior to touching the fuses.
Again it started fine, ran about two seconds then something shut it down.
When the key is turned, there's nothing but random/ very quick relay clicks at the panel, cd going through a cycle and it's acting as if the batteries are dead but they have a full charge and terminals are clean.
Old Jul 15, 2011 | 07:54 AM
Pocket's Avatar
Pocket
Could be a wide number of things, from a bad ground to a bad GEM.
Old Jul 16, 2011 | 05:55 AM
Edkajo's Avatar
Edkajo
Thanks, it ended up being a bad under hood connector.
It's odd how things like that happen at the exact moment something somewhat related is touched. I'm just glad it wasn't directly related to anything I did.
MomsAerostar
Aerostar
Dec 9, 2015 04:16 AM
frustrated mechanic
2004 - 2008 F150
19
Jun 10, 2015 04:15 AM
08GT500
Oct 8, 2013 02:04 PM
buckarooboy
Nov 1, 2012 09:30 PM
mahause
25
Apr 21, 2012 12:35 AM
