Sponsored by: Auxito
wheels
Old Jul 12, 2011 | 03:28 AM
jsiebs09's Avatar
jsiebs09
wheels
im looking to get new wheels for my truck. i have a 2001 f150 v8 ext. cab. i found some 16 in. x 8 in., 5 x 4.5 in. Bolt Circle, 5 in. Backspace. will these fit on my truck?!? and if not what will? thank you
Old Jul 13, 2011 | 03:07 AM
Bluegrass 7's Avatar
Bluegrass 7
No fit. The demensions are now metric.
Look at some other FORD truck wheel style.
Good luck.
Old Jul 14, 2011 | 01:51 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The bolt circle on your truck is 5x135mm
The 5x4.5 is what the Rangers/Explorers/Aerostars use.
Old Jul 14, 2011 | 09:32 PM
steve(ill)'s Avatar
steve(ill)
wheels from 1997 thru about 2003 will fit... 135mm pattern as mentioned. Prior to that the pattern was 5.5 inches ...ATC is right, the smaller trucks are 4.5 inch
the5schlueters
43
Nov 27, 2013 04:45 PM
1993 F250
Jul 1, 2011 02:32 AM
jojolima
All Things Towing
Feb 22, 2011 04:09 PM
balingwire
1997 - 2003 F150
Jul 10, 2005 12:47 AM
