f350 4x4 16 to 18in wheel swap question
edit: you already answered what i was asking in this post.
I don't go mudding, so I don't know much about the best tire for such other than what the guy uses on the truck can pull me out when i need a pull.
Depending on where you're at in arkansas, you can run into different types of mud and tires that work good in one type of mud will dig in with an other type. So ask the guys near you what tires they recommend.
You have 4.10 gears. I wouldn't be afraid to go up to 35x12.5" tires with your truck. You may need to trim or shim the front bumper a little for them to fit well. Otherwise 33"x12.5" tires will fit well.
The best mud tires that I've found that are streetable are Cooper Discoverer STTs. They are a very aggressive pattern, clean out well, aren't too noisy on the street, and look pretty good too.
Those look nice. kinda pricey but if they last its worth it. About $1228 for 4 on ebay thats a 275/65-18 LT325/60-18 are $1344 a set. how do I decipher the size?
They came off a 95 they were tried on a 2004 and didn't fit. I test fitted them on mine and went right on. the only thing I can find on them with a size is j9x18 whatever that means. I measured them and the bolt pattern is 8 on 6.5.
