No start condition
Old Jul 11, 2011 | 07:38 AM
rthacker's Avatar
rthacker
No start condition
This is what I have: 2004 F-250 late build with 178000 miles with egr delete done totally stock. The truck turns over but will not start. I have tried unpluging the ICP sensor. The truck has fuel pressure gauge shows 60psi. The scan gauge I have shows there is a linking problem so I cant pull codes. I thinking maybe the FICM has gone bad or the PCM. The day before it started strange like it was missing. Any help would be great.
Old Jul 11, 2011 | 03:09 PM
rthacker's Avatar
rthacker
May have found the problem. Was able to pull code p2285 which is icp low. That code was probably when I unhooked the sensor. I checked the FICM and got 48 volts when the key is on and 17.5 volts while cranking. I guess this means the FICM is bad? While I was checking the FICM the truck almost started. If I plugged the truck in would it start? Also when you first turn the key on the FICM would read 20 volts for about five seconds then would go to 48 volts is this normal. Thanks
Old Jul 11, 2011 | 04:23 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Volts would be there on power up. Checking at the FICM with a meter I think I saw a flash of 30 something at power up but scan gauge goes right to 48. Are you going to re-solder, get repair or replace FICM?
Old Jul 11, 2011 | 04:30 PM
m-chan68's Avatar
m-chan68
I guess we can chalk this up as the million and 1st FICM that has gone down the crapper for the OP.
Old Jul 11, 2011 | 04:57 PM
rthacker's Avatar
rthacker
I plan on using ficmrepair if I can get hold of ED. I saw this in another post and the cost of the repair looks good. I was surprised I didn't get a code. Anyway, thanks for this forum. Has anybody have any good feedback with ficmrepair?
Old Jul 11, 2011 | 05:06 PM
william_04_x's Avatar
william_04_x
That's a whole lotta FICM's.
Old Jul 11, 2011 | 08:33 PM
bismic's Avatar
bismic
I have used Ed from FICMrepair.com and am very well satisfied.
Old Jul 11, 2011 | 09:53 PM
rthacker's Avatar
rthacker
Thanks bismic, I just spoke with him on the phone. I will post the outcome when I get the FICM back in the truck. Thanks again.
Old Jul 12, 2011 | 07:21 AM
ID1982F150I6's Avatar
ID1982F150I6
I had a no-start condition recently, in which the truck started fine if it sat cold over night. Run it for a few hours, and back to a no-start again. No codes.
Dealer thinks it might be the High Pressure Oil Pump.
Gf2501
Jun 27, 2014 09:40 PM
afonda
Feb 16, 2014 10:12 PM
wickedclowns
Oct 13, 2011 05:36 PM
FUBARHUBAR
1997 - 2003 F150
May 19, 2004 12:36 AM
CrazyCajun67
Mar 4, 2004 11:50 AM
