Sponsored by: Real Truck
Ford V10 cam timing
Old Jul 9, 2011 | 02:43 PM
CR's Ford f250 SD's Avatar
CR's Ford f250 SD
Ford V10 cam timing
I have just recently done a head job on my 2001 ford f250 SD. I found that I had a leaking intake valve so I lapped the valves in both heads and re-installed using new head bolts and gaskets. Up on completion I timed it correctly with the crank mark @ the 6 o'clock position and the left cam at 12 and the right at 11. I even layed the chains flat and marked with a paint marker. But the truck seems really sluggish and has no throttle response at all. Any suggestions.
I was reading another post and some one said to put the crank key at 12 o'clock so the mark is @ 7 o'clock, Which is it the crank mark @ 6 or 7.
Azuber01
Jan 19, 2017 08:22 PM
Obowersox26
Sep 17, 2016 09:21 PM
bsraborn
Sep 5, 2016 07:36 PM
william16339
Jun 27, 2016 07:31 AM
deputydog03
Modular V8 (4.6L, 5.4L)
32
Apr 9, 2016 12:06 AM
