Ford 302 Timing Gear Alignment
Old Aug 20, 2016 | 07:05 PM
bsraborn's Avatar
bsraborn
I've been searching for a while to a question that I think has a simple answer... Hoping someone here can help me quickly.
New timing chain installed with cam sprocket aligned to crankshaft at 6 o'clock (cam) and 12 o'clock (crank). Is that the compression stroke for #1 cylinder or #6 cylinder?
I saw something that said this is #6 compression and in order to get the distributor placed so it's not 180 off, I would want to rotate 180 degrees so that Crank and cam point to 12 o'clock. Is this true?
Thanks for the help!
Old Aug 20, 2016 | 07:55 PM
351Cleveland C4's Avatar
351Cleveland C4
The cam timing determines everything. You have it set correctly at 6 and 12.
You can turn the crank over 360 degrees, be on the exhaust stroke, reset the timing gears and put it right back on the compression stroke without moving the crank at all.
Old Aug 20, 2016 | 08:09 PM
bsraborn's Avatar
bsraborn
Ok, yes that makes sense.
In summary,
-The crank is in the same spot every 1 revolution (360 degrees) the Cam is in the same spot every 2 revolutions (720 degrees).
-Cylinder 1 is on the compression stroke when the dots are at 6 and 12 o'clock as described above. This is where I want to be at when the distibutor is dropped in to avoid being 180 degrees off.
-Cylinder 6 is on the compression stroke when the dots are at 12 and 12 as mentioned above. I don't want to be here when I drop the dizzy in.
Others feel free to pitch in because I definitely read the opposite about 2 hours ago on a mustang forum... I think the way described here is correct. Otherwise it would seem that my rebuild book would have been sure to make a point of such an important step.
Thanks 351Cleveland! BTW I'm installing in a 74 F-100 with a C4 and mostly edelbrock components.
Old Aug 20, 2016 | 08:15 PM
351Cleveland C4
You've got it! If you get rotated the wrong way it's not too big a deal to find the proper stroke again. Just gotta pull the valve cover and watch valve action.
Old Sep 5, 2016 | 01:32 PM
bsraborn's Avatar
bsraborn
Just FYI for anyone interested, this information is correct. Fired the engine up with everything installed as described above and the timing was correct.
Old Sep 5, 2016 | 01:40 PM
351Cleveland C4
Of course it's right! I wouldn't steer you wrong.
Old Sep 5, 2016 | 07:36 PM
bsraborn's Avatar
bsraborn
ha-ha no doubt! Thanks again for the help.
HiDesertRat
2004 - 2008 F150
25
Jun 28, 2018 10:54 AM
F500Mike
Mar 28, 2013 09:00 AM
Green Streak
Apr 5, 2007 08:33 AM
melenko
General Automotive Discussion
Feb 9, 2006 01:01 AM
f100guy
Aug 18, 2004 09:37 PM
