New 460 in 76f250 timing problems!!
Old Jun 27, 2016 | 06:39 AM
william16339's Avatar
william16339
I put a new comp 292 cam in my 460. The cam dowl was at 6 o'clock my crank gesr, keyway and dot was at 12 o'clock. I put cylinder 1 at TDC. And dropped the distributor in facing the driver side firewall and all the plugs are in the correct order. She starts and runs like ****. Then blows and backfired through the carb and exhaust. Please help
Old Jun 27, 2016 | 07:02 AM
Filthy Beast's Avatar
Filthy Beast
There are two times #1 piston is at TDC - once on the compression stroke and another on the exhaust stroke. Are you sure you had #1 at TDC on the compression stroke and the rotor pointing at or just past #1 cylinder?
Old Jun 27, 2016 | 07:31 AM
OldStyle's Avatar
OldStyle
Rusty Roller
That's wrong.... Dots line up together like in this pic.
89er
Dec 1, 2017 09:30 AM
william16339
Sep 12, 2016 09:10 PM
bsraborn
Sep 5, 2016 07:36 PM
william16339
Jun 30, 2016 04:11 PM
laptopgeek
20
Jul 31, 2001 12:58 AM
