Help please
Old Jul 14, 2011 | 04:41 PM
hotroddsl's Avatar
hotroddsl
These injectors are really very durable and when they do fail it is usually just one at a time, but I don't think that's your problem.
Old Jul 14, 2011 | 04:51 PM
schlepprock250's Avatar
schlepprock250
I just did the UVCH on my friends truck,idled very rough,like on two or three cylinders,didn't have power to get out of its own way,turned out,the UVCH had worked loose,I did the .50 mod and fixed it,very doubtful it would be injectors causing this issue.
Old Jul 21, 2011 | 10:13 PM
Elitecrete1's Avatar
Elitecrete1
****have some answers***
Ok.....picked the truck up Tuesday, 1,500 dollars, 2 injectors, 2 uvch's and she is up and runnin. Truck runs great but first thing in morning one of the injectors is miss-firing. I talked to the mechanic and he explained to do the test that checks the injector the motor has to be warm, when the motor warms up the injector runs perfect. So therefore I can just deal with it till it gets worse or I can replace the other 6 injectors .... Thank y'all for all the help so far and what do y'all think about the mystery miss-firing injector?...
Old Jul 22, 2011 | 12:26 AM
kawcrasher's Avatar
kawcrasher
Let the truck sit overnight, and then start it with valve covers off and watch the oil deflectors on the injectors. The weak injector usually flows less, if any, oil.
Old Jul 22, 2011 | 12:29 PM
Elitecrete1
What do y'all suggest?..
What do yall think is the best programmer for my trucks I have three 2000 7.3's.....I own a concrete company and that's all I will use for my fleet trucks.....I need the bet programmer for towing and fuel milage?
Old Jul 23, 2011 | 01:39 PM
HD Rider's Avatar
HD Rider
Custom tuners blow the pants off any of the off the shelf programmers like Edge, SuperChips, ect.
Look at Power Hungry Performance, Total Diesel Performance, DpTuner, Beans, to name a few. They write tunes for your trucks with any mods you have made. I do not suggest running any programmer or tuner without gauges, EGT and trans temp (if auto trans) at a minimum.
Old Jul 23, 2011 | 03:23 PM
Elitecrete1
I have been looking at the dp tuner, and I have installed a triple gauge cluster. Trans, boost, and pyro. My problem is I'm trying to find a tuner that will do multiple trucks at once. Does anyone know of one that will? If not, I guess I am gonna go with the dp tuner. Also, why do you suggest customs tuners are so much better?
Old Jul 23, 2011 | 04:53 PM
HD Rider's Avatar
HD Rider
Superchips and the like VIN lock to your truck so they only work on one truck at a time. I don't know of any that will do multiple trucks.
Generic tunes that come on off the shelf programmers are writen to work with stock trucks. Custom tunes are writen for the upgrades you have done to YOUR trucks. Tuners also invest more time in writeing better tunes. My truck for example runs better in my economy tune than it did with the superchips performance program.
Old Jul 23, 2011 | 05:28 PM
Tailgate77478's Avatar
Tailgate77478
I don't know of any programmer that will let you do more than one truck at once...and understandably so. The manufacturer doesn't want to sell something that you could buy and program multiple vehicles with...heck, someone could go and start charging people to program their trucks on the side.
But as mentioned...don't go with a programmer. Chip it. HDRider named the top folks, and you won't go wrong with any of them.
Old Jul 24, 2011 | 11:35 AM
dothedew192's Avatar
dothedew192
I would go with a dp tuner if I was you. However, to answer your question about multiple trucks, I'm not sure about the other off the shelfers but my superchips programmer can tune other trucks. For 100 dollars you can add a truck to be programmed, and for another hundred dollars you can program two trucks. Three trucks is the maximum however. I've never done it but know for a fact you can. When you log in to your account to upgrade your tunes it has a little store where you can buy additional things for your tuner, the option to tune more then one vehicle is in there.
Old Jul 24, 2011 | 12:19 PM
Elitecrete1
Thank yall for the quick responses. I have learned more in the short time I've been a part of this forum than I have ever learned anywhere else. ....mods so for on my truck, 5" from turbo back, true "cold air intake" a-pillar triple cluster , boost, trans and pyro. And 22.5 semi wheels But I'm pretty sure the owner before me had a programmer on it and its still on it now.. how can I check to know for sure. It's way faster than my other 7.3 and they are on 250's
Old Jul 24, 2011 | 12:22 PM
Elitecrete1
What do yall think about doing the upgraded turbine wheel in the stock turbo ?
Old Jul 24, 2011 | 02:35 PM
  #28
dothedew192
I'm not sure how to tell that, more then likely it is though. And as for the upgraded turbo wheel, the main benefit of that is to get rid of turbo surge, no real horsepower or torque gains.
Fujis123
15
Jan 3, 2012 08:52 AM
400Nut
Modular V10 (6.8l)
Mar 10, 2011 10:55 PM
HawaiianPSD
40
Jan 10, 2011 01:33 PM
kdokey
Dec 29, 2009 12:36 PM
Magnapilot2k
Dec 14, 2005 07:58 PM
