Problem with my 01, need advice
Old Dec 28, 2010 | 09:00 PM
HawaiianPSD's Avatar
HawaiianPSD
Truck ran fine till this morning. Warmed her up for a few mins then hit the high idle for another few till the temp came up. Left work doing 15mph for a mile all good. Hit the highway and was good till 45-50mph then it started to run like ***, wouldn't rev to good, no power, just plain sluggish (oh yeah, engine light came on too). Pulled over and shut her down for a few seconds, fired her back up and the same thing. Switched tunes on my F5 and went back to stock to no avail. Was gonna have her towed but being 30+ miles up the mountain (expensive tow) I decided to limp her home. About 2 miles later the problem just went away and I was fine all the way home in any tune. Truck sat at home for 7 hours, I jumped in a few minutes ago and same problem, engine light on, idle kinda rough, sluggish. Left her sitting and used my lightning instead.
Anybody have any ideas whatz up? Truck has 125K miles. Thanks for any help guyz!!!
Old Dec 28, 2010 | 09:19 PM
Shake-N-Bake's Avatar
Shake-N-Bake
First thought is the wiring harness under your valve cover is coming loose. Have you secured that yet? I had the exact same symptoms as you describe and it turned out that I had a problem with #7 injector (armature plate screw was loose). In your case, let's assume the best and all you have is a loose connector under the valve cover.
Old Dec 28, 2010 | 11:37 PM
HawaiianPSD
gchavez, thanks for the reply brother!
What side valve cover? So the harness is under the cover as in you have to pull the valve cover off to get to the harness?
Old Dec 28, 2010 | 11:51 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Was it smoking real bad? turbo working extra hard? Sounds like the uhvc's. Pull both valve covers and do the 50c mod. Looks like ya haven't done the foil delete yet neither. Good time to do that,if you like turbo whistle. Hope we helped ya some.
Old Dec 28, 2010 | 11:55 PM
Skip1970's Avatar
Skip1970
i did the foil delete and it doesnt seem to make much of a dfference. the one mod that made a huge diff with the wistle was the open element filter mod from riff raff
HawaiianPSD
Wasn't smokin that I know of. What's the uhvc and 50c mod? Not new to these trucks but new to these problems... lol!
Old Dec 29, 2010 | 12:38 AM
diesel-fitter-bum01
Sorry meant UVCH, dam fingers. 50c mod is when ya take a quarter and trim the top down to the top of Georges head and slip it in the connector so it will stay tight and shouldn't come apart again. Can find pis on Chris's page(F350-6),good pics too. Hope it helps.
Old Dec 29, 2010 | 02:03 AM
HawaiianPSD
ok! so 50c is the homemade version of the wedge that ford sells to remedy the connector then. hope thats the problem. do you know if ford uses re-useable valve cover gaskets on our trucks like they did the fox body mustangs or do I have to buy new? Thanks brother!
Old Dec 29, 2010 | 02:12 AM
twags6's Avatar
twags6
Valve cover gaskets are reuseable (so is the gasket on the transmission pan for future reference). While you're under there, make sure the injector hold down bolts and rocker bolts are tight. Injectors bolts are 120 INCH/lbs (10 ft/lbs) and the rocker bolts are 20 ft/lbs
Pics of 50 cent mod installed, posts #11 and 14 here https://www.ford-trucks.com/forums/7...rs-manual.html
Old Dec 29, 2010 | 02:34 AM
HawaiianPSD
Thanks twags, appreciate the link bro! Crossing my fingers that this is the problem and not something more expensive.
So both sides have this harness that needs to be remedied?
Old Dec 29, 2010 | 02:52 AM
twags6's Avatar
twags6
No problem. Yes, you'll need to put one quarter under each valve cover, hence the name "50 cent mod". Its somewhere around $10 if you get clips from ford.
Old Dec 29, 2010 | 03:19 AM
HawaiianPSD
Thanks brother!
Old Dec 29, 2010 | 07:38 AM
Kwikkordead's Avatar
Kwikkordead
That should take care of the problem.
Old Dec 29, 2010 | 07:55 AM
danskool's Avatar
danskool
Go Bills !
When i did mine i had a injector hold down bolt loose. And one valve cover connector working its way out. And two dead glow plugs.
When i did dads he also had a valve cover connector almost disconnected. Surprised it ran ok for him. It was way out. Also he had Two injector hold down bolts loose. One was almost a full turn.
Old Dec 29, 2010 | 08:28 AM
Kwikkordead
Wow, mine were only 1/4 turn loose!
