Regulated Fuel Return Part II
Old Jul 7, 2011 | 08:43 PM
beanhead6D5's Avatar
beanhead6D5
Here is a what I did the first time https://www.ford-trucks.com/forums/9...wl-delete.html.
The reason for changing my set up is because I can't leave well enough alone.
Here is some pics of my new fuel system.
I started by modding a extra set of factory fuel lines I had.After cutting to length and some new bends,I brazed on a 3/8" JIC male end and then flared the other end for a female 3/8" JIC.
Here is the lines in place.The male end will run to the regulator return.The female end is the feed line to the rear of the heads.
I used the factory line to the pass side rear head as a pattern for the new line.The driver side line was ran along the top of the head.
Here is the regulator and front lines in place.
With using the factory lines I put the return line right back in place and hooked up my feed line to the factory fuel line.
My truck still runs the same I just like this set up much better.No rubber lines on the engine to worry about.
Old Jul 7, 2011 | 08:47 PM
snakedoc's Avatar
snakedoc
i like that how much did it cost.
what is the ss line from the head for?
Old Jul 7, 2011 | 08:52 PM
beanhead6D5
The SS line run from the HPOP.
I will have to add up everything and let you know.I think around $200.
Old Jul 7, 2011 | 09:08 PM
snakedoc's Avatar
snakedoc
that is not bad price. and i think it should last a long time.
Old Jul 7, 2011 | 09:11 PM
guitarpicr's Avatar
guitarpicr
Nice work there Brad - Looks good & clean
Old Jul 7, 2011 | 09:49 PM
mueckster's Avatar
mueckster
Great job, Brad. You've given me some ideas. I will be working on my fuel line upgrades this weekend.
Old Jul 7, 2011 | 11:58 PM
milleroutdoors's Avatar
milleroutdoors
Brad that looks good!
Old Jul 8, 2011 | 12:35 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Not bad, much cleaner. I like it.
Old Jul 8, 2011 | 08:51 AM
kccatpower's Avatar
kccatpower
that looks really good, when i put my rr in i was suprised at how small the stock lines and fittings are compared to the 3/8 line -6 fittings. to me it almost seems like overkill and have been thinking about dropping down to -4jic fittings and smaller lines to get a cleaner look.
Old Jul 8, 2011 | 03:56 PM
beanhead6D5
Thanks guys!
I plan on going to bigger injectors in the near furture.Thats why I went with the 3/8" lines.
If you stay with stock injectors I don't see a prob with running 1/4" line.
Old Jul 8, 2011 | 06:00 PM
jkidd_39's Avatar
jkidd_39
You gonna make it to RRE?
Old Jul 9, 2011 | 12:55 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Even going to bigger lines, still need to squeeze the fuel through a 1/4" fitting. I did go to 3/8" lines with my stock injectors. I am also planning to bigger. A difference will be noticed when fuel is flowing through all 4 corners.
beanhead6D5
91
Oct 28, 2019 07:12 AM
beanhead6D5
79
Feb 1, 2015 03:06 PM
beanhead6D5
Sep 26, 2010 09:47 AM
beanhead6D5
27
May 26, 2009 07:52 PM
