Clapping, no, not applause.
Old Jul 4, 2011 | 02:20 PM
LittleRadio's Avatar
LittleRadio
Just replaced my front warped brake rotors and pads. Purchased Bosch (with hub for my 2WD Excursion) rotors, and high performance pads. Made sure all parts were screwed back together nice and tight.
Took truck for a spin, and these new rotors were warped! Right out of the box? Label says "Made in China." Great.
Worse, I get a metallic "clapping" in sync with the pulsating when braking. WTH?
Quick poll -- any ideas? (Besides taking these damn Chi-com crap rotors back??!!)
Old Jul 4, 2011 | 04:40 PM
Skinsfan6's Avatar
Skinsfan6
Can you confirm that the rear rotors that you did not change aren't warped? Both front and rear rotors will warp. If both ends are warped and you replace one end, the other is still warped.
Old Jul 4, 2011 | 06:16 PM
labman1014's Avatar
labman1014
Not to hijack, but what will it feel like when the rear is warped?
Old Jul 5, 2011 | 11:19 AM
ppo2's Avatar
ppo2
In my personal experience, warped rear rotors feels just as if they were front warped rotors but less pronounced. Allow me to clarify; I knew I had warped rotors somewhere despite my after-market rotors and pads and proper break-in procedure. I could feel the pulse on the steering wheel but not on the floor board where one would imagine it would come from IF it were the front rotors that were warped.
Turns out that, yes, your rear rotors do warp even though they claim that 2/3 of braking is done at the front wheels. I still have OEM rotors in the back but after market pads on all 4 wheels. I've put in almost 35,000 miles and braking is still as smooth as the day I had the rear rotors turned.
Drive Safe,
Dan
Old Jul 5, 2011 | 11:50 AM
ukmat71's Avatar
ukmat71
are they grooved ? i mean, have you come from standard ones ? only know as my grooved ones make a hell of a noise till they got a bit of brake dust in the grooves
Old Jul 5, 2011 | 12:13 PM
labman1014's Avatar
labman1014
I don't feel it in the steering wheel. Just the floor and stuff.
Old Jul 5, 2011 | 07:41 PM
Stewart_H's Avatar
Stewart_H
Not sure what your options are for the rotors (what kind of warrantee they have) and the clapping could be so many different things, but it's not unheard of for brand new rotors, right out of the box, needing to be true'd up a bit on the lathe before being installed.
On all the rotor replacements I've done on my vehicles over these past 28 years, I've only run into one set of rotors needing to be hit on the lathe before installation. But my buddy who owns a brake and tire shop, and who does brakes all day long, say's it happens more than people realize.
Stewart
KJNDIVER
37
Aug 19, 2020 11:24 PM
Frank250Tank
16
Nov 16, 2016 06:41 AM
Big Sky
Jun 2, 2016 09:42 PM
My2000Expy
Aug 20, 2015 10:13 AM
RBRADBURY9753
Dec 26, 2002 12:34 PM
