Time for Brakes To resurface or not to resurface?
My rig is due for brake & suspension overhauling and I'm wondering if there is any point resurfacing the rotors..
I've inspected both front rotors and the surfaces are smooth with no ridges or warping. I had no pedal pulsation either.
I was thinking of scuffing down the rotors with some sand paper and throwing them back on.
Ive had a few shops tell me they can't turn these rotors (due to their design) and others asking a lot more money than I care to spend..
What do you guys think? Has anyone simply thrown pads/shoes on used rotors/drums that were in good shape?
My front brakes do drag quite a bit, but I believe that's attributed to the caliper pins & retaining clips not being properly greased. (I hope)
I have used a big disc grinder on my rotors to clean them up while someone spun the opposite side. they were still in spec and did not shudder after I was done
there are a few shops that can turn rotors on the vehicle but charge more
ebay has a bunch of choices from 40 and up if you want to swap them out depending on font end type
I only resurface rotors or drums if they are warped. Most perceived braking shuddering is the result of improper braking actions that deposit brake pad material on one spot of the metal surface. A few aggressive braking sessions from high speed (50 or 60 mph) to near 0 mph usually clears these.
Just my opinion...
Just my opinion...
Received 3,113 Likes
on
I appreciate the input guys. Front brakes are all done. I sanded the front rotors thoroughly and slapped them on along with re-packing the front hubs with grease. (MESSY)
I am finishing up the rest of the front end on my truck now. What a PITA its been. I'll be sure to post up my findings.
