Got a 1950 F-1 pickup. It was a service truck and had been sitting in a field for years. Popped open the flathead V8 for a look. It was locked up so I knew it wouldn't be pretty. I'm not sure if it is restorable. I'll have to find a machinist versed in flatheads to find out. What do you think by looking at the pictures? View Album
Start scraping on the deck surface, see if there are any obvious cracks. No question you have your work cut out for you, but if the bottom end is all rusty, it may not be worth it.
Hey guys I was just thinking, would taking a small wire brush and strategically/tediously going around the valves, head mounting surface, etc. removing surface rust work? Then trying to break up that rust down in the cylinders and vacuuming it out THEN adding the oil/penetrant work?
Short of hot-tanking it, that's the best plan. You wouldn't want to spin it with all that junk on it. Best to free up all the valves first, too.
Just take it all apart. Getting the crank to spin doesn't tell you anything. It's not like you are going to put the heads back on and run it like that anyway.
Agreed. Those rusty cylinder walls won't let it move anyway, IMO.
I'm going to put the solvent on and pop the bottom end open on it eventually. I'm suspicious that there will not be enough metal left to make rebuilding it viable. I don't want to spend a forture on it. The rest of the truck is going to take a lot of work to make roadworthy. If I can't move foward with the flathead, what is a good replacement engine to look for? I'd like to leave it as a manual shift truck. Also concerned with the rear end gearing. Is it more economical to look for another rear end (and if so, which one) or is there an add-on overdrive that would work better? Thanks Ford enthusiasts.
Flatties can be bored out as much as 1/8" on a good block, I wouldn't worry about the cylinders. The deck thickness and potentially cracks are the fears there. Plus just the cost if the bottom end is real rusty.
