NO START
Old Jul 3, 2011 | 03:29 PM
RBobby's Avatar
RBobby
NO START
2003 6.0L
Tried to start it this morning and sounds like a woodpecker in a tin can. Anything last ideas before I pull the starter? I looked in the tech folder and there is not much info regarding starter problems.
RB
Old Jul 3, 2011 | 03:33 PM
2006powerstroke90's Avatar
2006powerstroke90
So I am taking it..your getting a knocking while cranking it over?
Old Jul 3, 2011 | 03:40 PM
RBobby's Avatar
RBobby
Yup. Engine doesn't turn over, but starter is doing something.
RB
Old Jul 3, 2011 | 03:41 PM
2006powerstroke90
Ok, so the motor is NOT turning over.
Batt's fully charged? Check wire on the starter before pulling it out.
Old Jul 3, 2011 | 03:49 PM
RBobby's Avatar
RBobby
Correct, engine does NOT turn. Batteries are good.
Old Jul 3, 2011 | 05:29 PM
steelhead2's Avatar
steelhead2
Recheck your batts.sounds like there's not enough to engage the starter and its clicking on the ring gear.could be a bad connection too.
Old Jul 3, 2011 | 06:28 PM
bismic's Avatar
bismic
Originally Posted by RBobby
2003 6.0L
RB
There is a no-start troubleshooting thread in the Tech Folder. In that thread it tells you an easy way to get poer directly to the starter. If it doesn't turn ober that way, it is either your batteries or the starter.
There is a yellow with light blue striped colored wire adjacent to the passenger side battery in the engine compartment, near the vacuum pump that has a "squeeze-and-pull" type connection. Disconnect it, and jump the male end of the connector to the passenger side battery positive terminal. The starter should crank when you do this.
edit - I guess a hydrolocked condition could also prevent it from cranking w/ this trick.
triplehellcat
1997 - 2003 F150
Jan 4, 2014 06:13 AM
wmiller
Dec 7, 2009 12:00 PM
DJdemon6696
Aug 22, 2007 04:26 PM
cshook1
May 30, 2005 06:24 PM
Crumm
31
Nov 21, 2003 10:22 AM
