idi N/A performance
Old Jul 10, 2011 | 03:26 PM
starmilt's Avatar
starmilt
Why would new injectors hydrolock a cylinder, low compression on that particular would just make it harder to hydrolock wouldn't it. I'm thinking there had to be some slack in the wristpin, bad rod bearing or busted piston skirt.
Old Jul 13, 2011 | 02:17 AM
mike manglos's Avatar
mike manglos
well the possibility of a busted piston skirt is certainly there. A lack of compression would prevent ignition, where with old injectors probly allowed such small amount of fuel in that it was able to slip down past piston but with full amount of fuel it just stacked up till hydrolocing and broke rod just below wrist pin.
Old Jul 13, 2011 | 02:19 AM
mike manglos
[quote=FORDF250HDXLT;10557600]how many miles did she have on her Mike?
187,000
Old Jul 13, 2011 | 04:30 AM
starmilt's Avatar
starmilt
If the exhaust valve was opening like it should the diesel would be pushed out the exhaust every compression stroke, there would be no build up just raw fuel in the exhaust pipe.
Old Jul 13, 2011 | 10:40 PM
84-6.9L's Avatar
84-6.9L
Old injectors actually let in more fuel in because the holes are worn larger and stay open longer due to worn springs. The performance gain you see from new ones comes from better atomization.
Old Jul 13, 2011 | 11:02 PM
eatont9999's Avatar
eatont9999
I have not heard of a 7.3 failing like that without some other major factors being involved. New injectors should not send a rod through the block. Did the engine experience high RPMs or heat conditions at any point after the injector swap? The most likely result of compression being too high is head gasket failure.
Old Jul 19, 2011 | 08:54 PM
mike manglos
no it did not see high rpms nor did it get hot only drove for 2 miles or so. no need to ponder on why though, it happened so now i will be replacing the motor. a buddy found one about three hours from here for 350 bucks with only 155,000 miles on it. hopefuly its still there when i get the cash scraped up.
ronkwilson
Jun 1, 2017 09:08 AM
Greatwhite94
Jan 17, 2017 05:04 PM
rterril02
Jun 1, 2016 07:42 AM
Rockaholic
6.2L V8
Oct 1, 2012 08:18 PM
kjgibson2
15
Jun 18, 2012 05:34 PM
