I have a 02 f250 ext short box. I noticed today I was low on rear diff fluid. What type of fluid should I add. It is something I can get at walmart. Thanks
I just used the Mobil 1 synthetic 75w-140 in my 99, it has the LSD additive already in the fluid and it's been good to go in mine. I believe Walmart carries that, but any other auto parts store will have it. Make absolutely sure it's synthetic 75w-140, there's a tag on the diff that states synthetic fluid only.
im not sure if i have limited slip. truck is fairley new to me. Would supertech fully synthetic 75w-140 work? since im just toppping it off with a little.
You will likely have to look at the tag on the cover to find out if it is LS, but the supertech is just fine to use. If it rumbles a little when turning pick up some LS additive and add a little at a time till it doesnt any more.
hopefully i can still read the tag. So if it doesnt say limited slip then i dont have to worry about the additive? If it does maybe ill look for some 75/140 with the additive in it.
I think a lot of them have LS, especially if it's a 4x4 "Off-road" or FX4. If you don't have LS then you won't need to worry about additive, but I do think a lot of synthetics come with the additive blended in.
x2 on the Mobil 1
My truck has the Offroad Pkg, but didn't come with a LS rear diff. I upgraded to a Tru Trac, which doesn't require the additive also.
i just have 4x4 no off road package or anything. i could only read one tag on the diff it said to only use 75/140 synthetic. i looked on the door and by i didnt see anything that had ls by it. just k/31/9 by the axle part of the sticker. so im assuming i dont have have limited slip?
