Air Pump/ Catalytic conv.
Old Mar 28, 2003 | 09:03 AM
mjlevi's Avatar
mjlevi
Question: I have a 94 Ford F150 V8 351 vin. code 'H'...I have a air pump under the alternator, hoses go to and from a canister on the fender and then run along the exhaust manifold around the back of the heads and bolt to the heads themselves. there are NO tubes that go to the catalytic convertors, so can someone explain in detail and be technical please!.. how this system works and am I able to remove this system and the catalytic convertors (appears to be two convertors) without any problem to the EEC IV system?? thanks
Old Mar 31, 2003 | 10:09 PM
steve83's Avatar
steve83
If you follow the hoses off the air pump, one comes FROM the canister on the wheelwell (the filter) and one goes TO the plastic diverter/bypass valve beside the R exhaust manifold. From there, you might have one coming BACK to the wheelwell to a small exhaust muffler, but you should have one going to the crossover on the back of the heads and another to the cats. The Haynes manual explains the whole system very thoroughly, so that's where to find out more about it.
archtaan
WTB - Parts & other
Jul 10, 2012 08:12 PM
BillNYS
25
Dec 20, 2004 06:30 PM
boogity24
General Automotive Discussion
Jun 19, 2004 06:45 PM
oldhalftons
Mar 26, 2004 07:49 AM
vanman59
1978 - 1996 Big Bronco
Apr 25, 2003 02:51 AM
