best daily driver engine
Old Mar 27, 2003 | 11:39 PM
orangeford's Avatar
orangeford
What is a good engine to use as a daily driver in a 4x4 f150 with Air conditioning(NEED the bracket if changed) 3.50 gears, c6 auto and 33 inch tires? It currently has a 351m. I want low end power for get off the line power with 10 mpg or more. There arent any good pistons for the <a href="http://www.motorhaven.com/">351m </a>and I would have to find a 400 if I'm going to convert it. I have a <a href="http://www.motorhaven.com/">460 </a>but I need the pulleys brackets and manifolds. What are the differences in the <a href="http://www.motorhaven.com/">429 </a>and <a href="http://www.motorhaven.com/">460 </a>and the <a href="http://www.motorhaven.com/">351m </a>and 400? What would be goos for me?
Old Mar 28, 2003 | 01:01 AM
Torque1st's Avatar
Torque1st
Posting Legend
To convert a <a href="http://www.motorhaven.com/">351m </a>to a 400 at rebuild time all you need is the 400 crank and of course the proper pistons. To learn more about the 400 try the Cleveland forum. For more info re the 429/<a href="http://www.motorhaven.com/">460 </a>the 385 series engine forum has the skinny.
Old Mar 28, 2003 | 12:10 PM
78bigbronco's Avatar
78bigbronco
Everybody is gonna have a different opinion on whats the best motor. There are so many variables. I am not the expert on the <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">460 </a></a>but I know there are alot of aftermarket parts to build a real screamer out of it. But you gas milleage isnt going to be much better than 351m/400, if not worse. There is a fellow on these forums who built a couple 400's that got 14-15mpg with a <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">fuel injection</a></a> conversion. But the cam is also very important (as the stock <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">351m </a></a>& 400's came with pathetic cams that were a waste of metal). I would suggest edlebrock performer plus camshaft. Just my $0.02
Old Mar 28, 2003 | 04:40 PM
frankster123's Avatar
frankster123
i have a <a href="http://www.motorhaven.com/">351m </a>in my truck with a c6 and 2.75/1 gears. when it was still fairly fresh, it was quick off the line, for a truck.
it's got a burned valve now a gets sorry mileage.
i was going to build mine into a 400 but then got to thinking about how well it ran when it was fresh and decided i didn't need the bother of finding a crank, and getting pistons and the rings and the pins and keepers. a <a href="http://www.motorhaven.com/">351m </a>is plenty of power for this old man.
btw, check ebay motors works, there's a section on motor parts. search for ford/pistons. you'll find some 400, .030 over, flat top.
keep looking they'll show up.
Old Mar 29, 2003 | 11:38 PM
bigblue250's Avatar
bigblue250
<a href="http://www.motorhaven.com/">428 </a>Scj with twin <a href="http://www.motorhaven.com/">Holley</a> 800's LOL
Old Mar 30, 2003 | 08:00 PM
Chas1234's Avatar
Chas1234
My old mans 1978 F150 4x4 with a 400 and a c6 gets 16+ mpg . This is with a "stock" engine with a new edelbrock 4bbl intake and a holley double pumper . That isnt bad for a fullsize with a bigger engine and a 4bbl . I think it is how you drive the truck in other words if you keep your foot out of it but " blow it out" at least once a week you should get some good mileage .
At the same time my '75 with a 360 2bbl and a 4 speed gets 10 to 12 mpg on a good day ..that said I would go for the 400 it will have the off the line power you are looking for and ( with my old man's it will light up 2and gear if you stuff it at a 25mph roll) get good mileage ! The stock cam in my old man's truck is fine for pulling and normal driving/blistering the 30'' tires off the back !
Personally from what I have seen here the 460 really likes gas so you may want to stay away from that . ( I have never owned a 460 just an observation )
Jon
Old Mar 30, 2003 | 08:57 PM
BIG A's Avatar
BIG A
iam with bigblue250, a 428, twin carbs, strong low and mid range cam and headers will do the trick. add wings and a harness because with 2.75 gears your going to fly.
Old Mar 30, 2003 | 09:33 PM
Torque1st's Avatar
Torque1st
Posting Legend
Come on guys, the user asked a question and would probably like some serious replies.
For a fullsize Ford the 300-6 is a great engine for a daily driver as long as it is in good shape. The 400 offers a good choice for a daily economy, when built properly, and still has the power for some towing etc. This assumes that the vehicle is geared properly for the engine application. IMHO the 460 is great if you want to do some regular towing but it sucks too much gas for a daily driver. The 460 is hard to get geared right to take advantage of the low end torque it has. Some of the old full size luxury cars used diff ratios in the 2.x:1 range to use the 460.
Old Mar 31, 2003 | 03:10 PM
cobra413's Avatar
cobra413
I don't know I don't meen to offend anyone but I haven't seen any ford motors that are more than 351 cid that get over 10 mpg. I own a 1977 f-250 with a 390 I installed and a 1976 f-150 with a 351m in it and a lot of ford motor experience I think you would be better to buil a 351 cleveland or 351m. I have also owned a 360 cid and a stock 390 cid. 360 & 390 stock both get between 7-10 mpg full load or not
Old Apr 1, 2003 | 01:20 AM
bigblue250's Avatar
bigblue250
Unhappy best daily driver engine
A 77 with a 360/390 and a 76 with a 351m don't confuse me I thought it was the other way around?????
Old Apr 1, 2003 | 01:37 AM
Torque1st's Avatar
Torque1st
Posting Legend
Mileage will depend heavily on the final gear ratio. A truck that gets close to the same (low) mileage loaded or empty is usually geared to low (high numerically).
I have never liked the small V8's for truck use, just my penny's worth...
Old Apr 1, 2003 | 06:53 AM
MitchPeters's Avatar
MitchPeters
My '79 F250 4x4 got 8-10 MPG stock w/351M Auto full time 4x4 w/3.54 gears. It got the same with a BUILT 400 auto and then a 4 speed and part time 4x4 and 4" lift and 35x12.50 radials. It did not matter if it was loaded or empty or towing. 8-10 mpg. I do have a heavy foot though. HEHE!!!!!
Old Apr 1, 2003 | 10:54 AM
cobra413's Avatar
cobra413
I have a 1976 f-150 and a 1977 f-250. I did a swap and took the 351m out of the '77 and put the 360 into the '77. before I put the 360 in though I took it to a performance shop and turned it into a 390 thats bored out .80 over with all the parts to go along cam, carb all that stuff, too many to list. So I hope that clears things up.
Forever truckin
ba 302
1978 - 1996 Big Bronco
Mar 12, 2009 03:59 PM
Raintree55
Apr 24, 2003 08:38 PM
twix4x4
Mar 28, 2003 11:38 AM
wamp12000
Mar 28, 2003 05:00 AM
nike_z
Mar 26, 2003 03:33 PM
