Installing Duraspark in a 351C
Old Mar 24, 2003 | 06:03 PM
wamp12000's Avatar
wamp12000
I am getting ready to change my ignition system from the original points system to a duraspark ignition out of a 351M.
I am installing a msd blaster 2 coil with the stock module and distributor out of the M.
Am I correct that it is just a simple switch over? And if so, what should the timing be set at?
I have a <a href="http://motorhaven.autoanything.com/"><a href="http://motorhaven.autoanything.com/">351c </a></a>2v .
Any advice or recommendations would be appreciated
Old Mar 27, 2003 | 09:55 PM
MrMotorsport's Avatar
MrMotorsport
Swapping distributors? Easy enough transfering the module and harness, but the distributor from the <a href="http://www.motorhaven.com/">351m </a>won't work ( I believe), I think you need to obtain one from a 460, they are interchangeable between <a href="http://www.motorhaven.com/">351c </a>and 460's.
Old Mar 27, 2003 | 11:35 PM
79Lariat's Avatar
79Lariat
351C, 351M, 400, 429, <a href="http://www.motorhaven.com/">460 </a>all use the same distributor. 351 W, will also work if you change to a <a href="http://www.motorhaven.com/">460 </a>drive gear.
Old Mar 28, 2003 | 05:00 AM
Brian S's Avatar
Brian S
The <a href="http://www.motorhaven.com/">351m </a>distributor will work but the mid to late '70s had tempermental control modules. The advance curve is slow for emissions purposes.
An easier way would be a Pertronix conversion.
http://www.pertronix.com
skips69
Mar 31, 2003 07:37 PM
panteramatt
24
Mar 28, 2003 04:00 PM
stemen_a
Mar 28, 2003 11:23 AM
Quadiquizm
Mar 27, 2003 02:13 AM
jpb222
Mar 25, 2003 05:02 PM
