Engine Shutting Off
Old Jun 27, 2011 | 08:17 PM
bayous's Avatar
bayous
Engine Shutting Off
Hi Guys;
i have a 1998 Expedition , which i love..
But Lately when i come back from the train it has turned of about 6 times. Mind you its only a 2.5 mile drive.. and today i cranked it up to see how it was doing and it was idling super rough.. when you throttle it up it smooths out then it turns off...
Help
Old Jun 27, 2011 | 09:22 PM
alloro's Avatar
alloro
Turns off with the throttle up, or after it comes back down to idle?
Old Jun 27, 2011 | 10:44 PM
bayous's Avatar
bayous
Back down to idle. And when idling. Real rough
Old Jun 27, 2011 | 11:03 PM
lv2race's Avatar
lv2race
Start by checking for codes. Clean the IAC, MAF, and the throttle body, all easily accessible and that should help with the rough idle. What motor do you have?
Old Jun 28, 2011 | 12:34 PM
pdqford's Avatar
pdqford
And check the PCV elbow for the famous vacuum leak!
Old Jun 28, 2011 | 12:42 PM
bayous's Avatar
bayous
Is the a schematic showing where that is located
Old Jun 28, 2011 | 01:26 PM
pdqford's Avatar
pdqford
No.
I don't think you indicated what engine you have. But basically, its around the back side of the intake manifold. IIRC, on the 4.6 its not visible, but you can find it by feel. Just follow the PCV hose from the right side valve cover and you should "feel" the elbow to see if its all soft and mushy (trademark term ) or colapsed.
Old Jun 28, 2011 | 01:52 PM
bayous's Avatar
bayous
5.4 L 1998 4x4 Eddie Bauer Exepdition
Old Jun 28, 2011 | 06:35 PM
alloro's Avatar
alloro
No but there's a picture, it's in the red circle: https://www.ford-trucks.com/forums/1...ml#post9460693
If you have the 5.4L motor then clean the IAC as shown in this thread: https://www.ford-trucks.com/forums/9...4l-triton.html
csoddy
Sep 30, 2015 09:50 AM
Munch
Jul 4, 2006 05:26 PM
MountaineerAWD
Escape & Escape Hybrid
Apr 4, 2006 09:25 AM
Matt M, PA
Feb 14, 2005 09:00 AM
J. E. Ray
2004 - 2008 F150
Mar 14, 2004 12:56 PM
