2005 Expedition A/C vent problem
Old Jun 25, 2011 | 01:27 PM
Caroline764's Avatar
Caroline764
Rookie user here - appreciate any help possible! Thanks. A/C works fine in back, is blowing through the defrost vents but not 4 main dash vents. Can't see any breaks in vacuum hose behind battery, though there was some corrosion on terminal, which was cleaned off at last oil change. No thumping or clicking (that was last year, had the system replaced) but heading out on vacation soon and hoping for a quick fix, not a huge bill at the dealership...appt Mon morning. Had new Triton engine installed in the fall due to bent rod; thankfully under warranty but that's the only other known behind-dash work done. Thanks for your help!
Old Jun 25, 2011 | 02:56 PM
Caroline764
Replaced vacuum hose; a little more output through the 4 vents but still not as strong as before. Still strong output through defrost vents. Any ideas?
Old Jun 25, 2011 | 03:04 PM
alloro's Avatar
alloro
On the driver's side of the floor hump, looking up at the heater vents. You should be able to see a vacuum operated actuator, right above the carpet. There might or might not be a flimsy cover in the way, if so remove it. But I'm fairly certain that actuator is one that closes off the floor airflow and directs it up to the vents. I've seen it's linkage fall off before.
Old Jun 25, 2011 | 04:24 PM
Caroline764
I'll take a look - thanks!!
Old Jun 27, 2011 | 11:42 PM
Caroline764
Still bedeviled by this - couldn't see anything on the drivers side. Any possibility of going in through the glove box to see what's behind? By my estimation, that's about where the 2 hoses/wires (grey, black) come through the firewall. Read about other Expy models that you could do that; don't know if it's worth the effort. Clearly there's a vacuum problem somewhere, because fixing what we could see made for better flow but still not the great flow of the past. Thanks to all who've read - looking forward to learning more from y'all as you post!
Old Jun 28, 2011 | 06:16 PM
alloro's Avatar
alloro
Here's the part I'm talking about. This is at the driver's floor, the brake and gas pedals are to the left.
Old Jun 29, 2011 | 01:54 AM
Caroline764
Wow, not even close to what I was looking at - so glad you posted this picture for me. Thank you! I'll take a look tomorrow. Again, thanks so much for your help!
chiefjefe
75
Jun 13, 2017 09:02 AM
RMeans
Apr 21, 2016 08:36 PM
bulletpruf
Aug 1, 2013 11:08 PM
wgm114
Aug 12, 2012 09:24 PM
AeroStarOwner
Aerostar
May 9, 2012 11:01 AM
