ECM... serious electrical problems...
Old Jun 27, 2011 | 06:32 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
Question ECM... serious electrical problems...
Back when i first got my truck (before i knew anything about our trucks, please don't make fun of me!!! lol) i bought an Edge Evolution programmer. Plugged it in, and it wouldn't comuicate with my ECM... After doing research, i got alot of ppl saying Edge is crap, so I just sent it back, thinking it was the programmer. when i got my injectors checked out, the mechanic couldn't get his diagnostic machine to communicate either. his exact words were, "brother, you got some serious electrical problems, cause i can barely even get this reader to turn on." And that was about all he had to say about it. Which brings me to my point. I don't know a whole lot about the electrical side of our trucks, and i don't wanna spend a huge amount of money figuring out the ECM thing at a shop. So where's the best place to start trying to sort this out myself?
Old Jun 27, 2011 | 06:39 PM
427 fordman's Avatar
427 fordman
Unless you're pcm has been flashed with an update, if its the 94 in your pic, the obdII port won't work. It has a different hookup under the hood iirc.
What problems are you having?
Old Jun 27, 2011 | 06:44 PM
f350rebel7788
yeah, when i tried the edge, i just used the port under the dash, but the mech tried both the one under dash and under hood, and had the same result. does this mean that i might not have electrical problems, i just need to flash the PCM??? as far as how the truck runs, it's running perfectly (as far as i know, but i'm guessing it's had these problems since before i got the truck, so maybe im just used to messed up), other than the fact that none of the readers or programmers will register & vice versa.
Old Jun 27, 2011 | 09:19 PM
DIYMechanic's Avatar
DIYMechanic
I think your truck is fine. Unless the scanner is made especially for a PSD, it likely won't communicate with your truck since your truck isn't an OBD II compliant vehicle. If it runs fine, I say just don't worry about it. Most of the scanners and code readers you find out there will not work on our trucks. You should be fine. Save your pennies and get a chip from one of the site sponsors on here. They can hook you up with a chip that WILL work on that truck.
Old Jun 27, 2011 | 09:22 PM
f350rebel7788
okay... well i guess that makes sense, cause i want to get tunes anyways, so worst case, i get the tunes, try em, find out the ECM is actually messed up, then at least i have the tunes and know what needs fixed... lol
Old Jun 27, 2011 | 09:24 PM
DIYMechanic
Yeah and if you need something to read codes and streaming PCM data, you may want to look into a scangauge. I can't say for sure that it will work with your PCM, but if not, you can have your PCM re-flashed by the dealer to the latest and greatest codes and then the scangauge will work for sure. Quite a few on here have them and seem to be very happy with them.
Old Jun 27, 2011 | 09:30 PM
f350rebel7788
ok, well that almost makes me feel good, other than the fact that i actually paid the mechanic that said it was broke for his work on my injector... which is a sore subject in the first place... oh, well, you live you learn, and when in doubt, i've learned to trust the good ppl here! lol
Old Jun 27, 2011 | 09:32 PM
DIYMechanic
Yes sir, these guys will give you honest advice every time. This site is the best tool out there for our trucks! A true wealth of knowledge.
Old Jun 27, 2011 | 09:34 PM
f350rebel7788
thanks alot man, reps sent for the help! and you're not kidding! when i first joined, i knew nothing about anything on these trucks, and with the help of the guys on this forum, i've learned A LOT, and have been able to do quite a bit of work on my truck that i never would have been able to do without these guys!
Old Jun 27, 2011 | 09:37 PM
Action4478's Avatar
Action4478
Get thew PCM re flashed or pick up a new used one , then get your money back from the knuckle head mechanic
Old Jun 27, 2011 | 09:39 PM
DIYMechanic
No problem man. I'm glad to help on the ones where I can. It's the least I can do after having been in the same boat and learning SO much about these engines.
Old Jun 27, 2011 | 09:46 PM
f350rebel7788
what's it usually cost to have the PCM re-flashed?
Old Jun 27, 2011 | 09:55 PM
Action4478's Avatar
Action4478
Call the dealer ,I would expect to pay $100.00 or so , a used PCM may be as cheap as $50.00 (car -part .com)....
Tronick
1978 - 1996 Big Bronco
40
Apr 6, 2023 09:06 AM
2002exPSD
Computer Chips & Tuners
Jun 26, 2022 05:13 PM
peterso
May 26, 2021 06:30 AM
glockholiday
Apr 18, 2015 12:48 PM
fordf150guy
Dec 7, 2013 10:59 AM
