Sponsored by: Real Truck
backup sensors
Old Jun 27, 2011 | 12:38 PM
cjlvashon's Avatar
cjlvashon
backup sensors
I have a f350 super duty deisel. The backup sensors have quit working. They worked fine until we had a hard freeze. Any ideas
Old Jun 27, 2011 | 01:30 PM
TobiasR.'s Avatar
TobiasR.
I would change the sensors, is cheaper than searching the fault. Because I don't think that the wire have a problem, But go all sensors to one plug ? or have all sensor their own wire ?
If they go to one plug check the connection
best regards
Old Jun 27, 2011 | 08:42 PM
pbeering's Avatar
pbeering
All the fuses OK?
All the sensors clean and intact?
If so,
Get a can of electrical connection cleaner, some dielectric grease, a towel, a creeper and a light and crawl under the bumper. (safety glasses too)
Remove each plug, check for corrosion, clean as needed, then repack with dielectric grease. A small screw driver may be helpful. Be patient and wipe off crud first.
Check the connection of the sensor array to the harness (beside the spare tire)
Test.
Check dash defeat switch.
Any single connectio failure will defeat the whole system.
And they are $85 each from,parts guy Ed.
Old Jun 27, 2011 | 08:51 PM
lakedweller's Avatar
lakedweller
Wow, $85 each for sensors, I wanted to put sensors in my front bumper...
bbender85
Mar 28, 2013 03:54 PM
73FOMO
Dec 28, 2011 01:59 PM
kwaskow
Jul 21, 2011 09:30 PM
Miguy
Mar 21, 2009 07:54 PM
burgf250
Feb 19, 2009 09:08 AM
