Sponsored by: Real Truck
a/c issue
Old Jun 23, 2011 | 07:29 PM
countryboy73703's Avatar
countryboy73703
a/c issue
ok.. short and sweet.. a/c works fine and cold at idle, but when I take off or my rpm's are up, you can almost immediatly feel a different in air temp getting warmer.. not hot.. but deffinently not as cold as it is at idle.. for me that seems weird, because you would think that it would get colder as you move to do the pully for the compressor turning faster, but hey I'm on an a/c tech.. and yes I have plent of r34 (<-- I think) in there, cause I tried to recharge, and it wouldn't take any, hell a tiny bit came out of the system.. not enough to matter, the only thing I can think to do is get an a/c flush, which I'm sure isn't cheap, and I'm a do it your selfer, so I'd rather not.. any ideas?
Old Jun 24, 2011 | 06:01 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It may be overcharged. What are the high and low side pressures? I'd NEVER add r134a without knowing the pressures.
Old Jun 24, 2011 | 01:22 PM
countryboy73703
Not sure what the pressures are.. that's just what I used to do with my last truck cause it had a slow slow leak
Old Jun 24, 2011 | 04:31 PM
dvlishdan's Avatar
dvlishdan
Mine is acting just the opposite. At idle my A/C temp is at 80 degrees once I start rolling it drops to 60 degrees. I assume it is due to the fan not pulling enough air to cool the core.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Aug 22, 2010 02:28 PM
997.3okie
Sep 20, 2006 12:32 PM
Hautewheeler
Aug 18, 2006 01:35 PM
oshoguno
Aug 21, 2005 10:04 PM
