Sponsored by: Real Truck
brake pressure
Old Jun 23, 2011 | 07:21 PM
countryboy73703's Avatar
countryboy73703
brake pressure
alright... so I was having an ABS problem. but that was solved when I replaced my hub assembly/sensor, so here's the issue, cause I"m honestly not sure, and was to get a shout on here before I get a diagnostics done at the dealer, so my brakes work.. but they loose pressure, and I have to push them down more and more as i'm stopping, and once I stop they still loose pressure op to about 2 inches from the bottom... it shouldn't be doing this.. even if I"m just backing out of the drive, to go to work, when I stop in reverse to put'er in drive, pedal still goes WAY down... however, I thought that it might be my master cylinder but, I don't completely lose pressure, I almost feel like theres air in the brake lines, but I bleeded them already, I guess I can try again, maybe I didn't get it out.. but I really feel like it's something else.. any ideas would be greatly appreciated, and thanks in advance.
-Josh
Old Jun 23, 2011 | 07:23 PM
countryboy73703
also, once i come to a stop, I let off the brake and quickly apply pressure again so that my pedal isn't bottomed out, cause I'll start moving again while trying to be stopped..
Old Jun 24, 2011 | 11:35 AM
mwsF250's Avatar
mwsF250
With constant foot pressure, does it stop sinking at some point before it reaches the floor?
Yes: Still air in the lines.
No, it sinks to the floor and then even after repumping, it keeps sinking: Leak.
Old Jun 24, 2011 | 04:36 PM
countryboy73703
Ok well ill re bleed them just to make sure.. I knw its not a leak because my resevoir stays at the same fluid level
stephenok711
Jun 2, 2012 05:59 PM
DCRB
Aerostar
28
Jan 5, 2010 02:20 AM
stangman516
May 12, 2009 02:22 PM
baddboy
Dec 11, 2008 05:56 AM
country2
24
Aug 6, 2007 06:21 AM
