On my wife's vehicle I just had the A/C recharged. The A/C never really worked well last year and she complained it smelled so I put in the antimold stuff into the vents. While traveling at a constant speed on the highway the a/c will blow very cold for 5 minutes then go warm. If I turn the a/c off for a minute and then back on it will blow cold for another 5 minutes. I admit I don't know much about a/c systems but what I did notice is that the one line from the compressor gets very cold and water condenses on it. The other line gets almost too hot to touch. I ran the a/c in the driveway at idle for a while and it blew cold air no problem but I didn't notice any water dripping from underneath. What could the problem be or what should I be looking for to get closer to a solution. Any help would be greatly appreciated as we want to sell it and can get more money for it and sell it easier if the air works. Thanks everyone.
Could be the condenser coil needs cleaned. It looks just like a radiator and is located right in front of your radiator. Spray it really well with your garden hose and try to get all the crap washed out.
The refrigerant in the air conditioner loses pressure as it loses heat. The coil acts like a big heat sink to carry away heat and consequently to lower the pressure. If it is plugged the pressure will build up until a safety switch shuts down the compressor. Turning the AC off resets the safety.
