1978 - 1996 Big Bronco
brake problems
Old Jun 22, 2011 | 06:49 PM
MaceKing's Avatar
MaceKing
brake problems
i have an 89 bronco i just bought...it has some problems with it...vacume hose leeks, needs a tune up, some fluid leeks, but my main problem im trying to deal with right now to get it to pass saftey is the brake problem..... the ebrake light is always on and my rear pass. brakes are sticking and burning up... i just replaced the rear brakes, and everything else inside the drum...(springs, adjuster, and wheel cylinder) the brakes are still sticking and only on the rear pass side.....can anyone tell me what the problem could be??????
Old Jun 22, 2011 | 06:56 PM
MaceKing's Avatar
MaceKing
i read on here that it may have something to do with the ebrake cable and replacing that might fix my problem i was wonderfing if any of you older folks that know more about fords can help me
Old Jun 22, 2011 | 07:53 PM
Southern Bronco's Avatar
Southern Bronco
Check/replace you e-brake cables.Sounds like they are sticking
Snorri_B
Jun 8, 2013 11:06 PM
aaronlaaron
Oct 27, 2012 03:50 AM
Ford5.8XLT88
26
Jul 21, 2011 04:29 PM
tcervi1028
Dec 2, 2003 07:51 AM
