What's the difference between the van turbo and the stock turbo on our trucks? What is needed to do the swap? Anybody know whether a turbo off a 2001 E series will work?
The van turbo is the same turbo we have on our trucks. The SD guys do it as an upgrade from their factory one.
There is no benefit for us to convert to SD other than the use of a Garret 38R as a direct bolt on upgrade turbo.
No. The van turbo is our stock turbo but with SD connections.
Ford used our turbo a bit longer on the vans than they did on the trucks.
If you have a d66, keep it. If you want a 38R swap everything over to SD stuff. I would stay away from the 38R and go with a different turbo setup. Either d66 or H2e depending on your price range and mods.
No, I mistakenly typed that and saw it after the fact. I just have a stock turbo. The one I saw listed was just listed as a van turbo. I wasn't sure what it was. Sorry for the confusion.
