1985 Window Motors
Old Jun 19, 2011 | 06:35 PM
Fratzog440's Avatar
Fratzog440
1985 Window Motors
Ok so I have an 85 F250 Lariat with electric windows. Both windows stopped going up yesterday. The motors turn but the windows don't move. It happened suddenly. Both worked perfectly then my passenger stopped working yesterday and my driver stopped today. Anybody have this problem or know what is causing it? Thanks
Old Jun 19, 2011 | 07:50 PM
Anafiel's Avatar
Anafiel
Maybe the plastic gear bushings both went out simultaneously?
Cardone Reman/Window Lift Motor Gear Kit (42-91) | 1985 Ford F150 1/2 ton P/U 2WD 8 Cylinders H 5.8L 4BL Windsor HO | AutoZone.com
Old Jun 19, 2011 | 07:52 PM
ctubutis's Avatar
ctubutis
I would remove the door panels and look inside.
Old Jun 19, 2011 | 08:02 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
That gear that is mentioned by anafiel is prone to breaking.
The only thing I can think of that would cause the motor to still turn or spin, without triggering the breaker.
If the window was stuck, the motor would try to "Roll" up the glass and stall, eventualy triggering the breaker and shut off.
You will need to remove the door panels, and the plastic shield to see what's going on.
I would also use some silicone lubricant on the window rubber strips. It will clean and protect them, and make the window slide in the rubber channel easier.
Old Jun 19, 2011 | 08:23 PM
Anafiel's Avatar
Anafiel
I forgot to mention that you can get the plastic bushings separate for about $7.00 or so off of the Help! rack. They come as a set of three, which will do one motor.
I had to do both doors and tailgate on my Bronco this year.
Old Jun 19, 2011 | 08:39 PM
Gary Lewis's Avatar
Gary Lewis
Or, you can make bushings yourself out of fuel hose. It is easiest if you have a bushing left so you know what the diameter and length should be, but you can do it without a good bushing - I did. And, while you have the gear box apart you should clean the grease out and repack it.
But, you will have to drill a couple of rivets out to get the mechanism out of the door. Not difficult at all, and when you get things lubed you'll be surprised at how fast and smooth the windows go up/down.
Old Jun 19, 2011 | 10:38 PM
JimsRebel's Avatar
JimsRebel
Rubber fuel line??
or plastic hose?
Old Jun 19, 2011 | 10:51 PM
Gary Lewis's Avatar
Gary Lewis
Maybe either if you mean vinyl tubing when you say "plastic". The "bushing" is actually a shock absorber, so you want something with give. But, it also needs to be firm enough to not flex a bunch each time and crack. I used rubber and it works well. Vinyl might work if it has a thick enough wall.
Old Jun 19, 2011 | 11:00 PM
JimsRebel's Avatar
JimsRebel
http://cgi.ebay.com/ebaymotors/Ford-...item53e7fb5acc
Is this the part needed?
Old Jun 19, 2011 | 11:17 PM
Anafiel's Avatar
Anafiel
Originally Posted by JimsRebel
That's them. Actually, those are a really good idea. Looks like he took some kind of nylon dowel and cut it up into window motor bushings.
Good idea, and he has them for a good price, if you can live with his shipping cost though....
Gary Lewis's Avatar
Gary Lewis
Yes, that looks to be the part.
Old Jun 19, 2011 | 11:49 PM
Rogue_Wulff's Avatar
Rogue_Wulff
I couldn't tell you the number of times I have used 3 x 1/4" hex nuts inside those window gear drives. No, it isn't the "right" way to repair the problem, but I have never had to do it again......
teamlx88
May 21, 2015 08:30 AM
BFTUFF
1997 - 2003 F150
36
Apr 27, 2014 04:24 AM
Built-Ford-Tough91
1978 - 1996 Big Bronco
Sep 5, 2013 05:20 AM
SpeedRebel09
Jan 23, 2013 09:11 PM
