Sponsored by: Real Truck
99 f250 power windows problems
Old May 4, 2012 | 11:02 PM
SpeedRebel09's Avatar
SpeedRebel09
Alright so I've been having problems with my passenger window having trouble going down. It'd go about 3/4 the way and slow down and sometimes stop.
Well today I took my door lock actuators apart to repair the motors as the resistor burn up. Well to do this it requires you remove the bottom half of the window tract and push it out the way. After reassembly of everything both windows are not working. They will open approx 3 inches and stop almost like they're bound up?
Im stumped, the motors are working. I lubed all tracks of the regulator as well as the window tract itself. Any ideas?
Old May 4, 2012 | 11:09 PM
SpeedRebel09
Btw truck is a 99 f250 super duty xlt extended cab
Old May 7, 2012 | 07:15 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
Fix it yet? I would loosen the glass and slide it up and down to be sure it is not bound up. Then hold it up or remove it then run the regulator up and down to see what is causing your trouble.
Old May 7, 2012 | 08:26 AM
SpeedRebel09
Nah I ain't fixed it yet. Thing that kills me is they worked fine before I removed the bottom of the window track. But now that I put it back together its giving issues
Old Nov 16, 2012 | 02:26 AM
whargraves's Avatar
whargraves
I was just wondering if you happened to fiqure anything out on your window problem. I am having the exact same problem have just been dealing with it, and thought I would do a search and see what I could find and this post came up.
Old Dec 2, 2012 | 06:27 PM
boj760's Avatar
boj760
Speedrebel, figured anything out with your windows? Mine are also doing the same thing. Just wondered if you found anything before I tear my doors apart.
Old Jan 23, 2013 | 07:19 PM
walkinghorse's Avatar
walkinghorse
same problem
has anyone found a fix I replaced the power door lock actuators and now the window will just go down a little and it stops checked the motor and it is working fine, any one have any thoughts.
Old Jan 23, 2013 | 09:11 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
When I replaced my door lock actuators I didn't have to take anything off the windows.I'm quessing you put the window or lock linkage together wrong thats why its binding up. My driverside window goes down 3/4 of the way and stops when cold. I think it needs a new power window motor.I'd take the door panel off and hook up just the switches and watch as the window moves to see whats going on inside the door.You should be able to see whats happening.
F-150 LARIAT
1997 - 2003 F150
Feb 1, 2011 02:41 PM
f350ford17
Jan 4, 2008 08:40 AM
RMbros
1997 - 2003 F150
16
Jul 3, 2007 11:42 AM
homer4.2
2004 - 2008 F150
Oct 28, 2005 12:32 PM
mrmootsie
Mar 11, 2004 03:02 AM
