6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
diagnosis please
Old Jun 19, 2011 | 10:38 PM
Texas450's Avatar
Texas450
Originally Posted by bigcountryfs
i was told they needed to pull cab to make it much easier, some might do it without pulling it. luckily mine was still under warranty.
Is that considered part of the turbo
Old Jun 20, 2011 | 10:57 AM
bigcountryfs's Avatar
bigcountryfs
i'm not sure. i believe it had less than 36000 on it at that time.
Old Jun 20, 2011 | 10:59 AM
Texas450's Avatar
Texas450
I have a esp....but I think it only covers the turbo....not sure if the downpipe is included
Old Jun 21, 2011 | 08:36 PM
Texas450's Avatar
Texas450
It turns out that I have a small crack in the exhaust pipe coming from the turbo. Will run 1500 to 2000 bucks.....I was told that I don't need to fix it right away because its so small and im getting more than enough boost .... if I leave it be... will it cause damage to the turbo or engine?
Old Jun 21, 2011 | 08:41 PM
senix's Avatar
senix
no, just get louder over time. You might consider fixing it before winter as well. You don't want to risk fumes in the cab with the heater on.
That is my thoughts.
Here is something else. I was on http://www.nhtsa.gov/ today and I thought I saw something about a warranty extension for that pipe. Maybe I am wrong but go there and look at the bulletins. It is not a recall. See if that is one that applies.
Old Jun 21, 2011 | 08:47 PM
Texas450's Avatar
Texas450
Good point.... on that since I do sleep with the truck on when im in north dakota and its -15 degrees lol....does anyone know what causes the crack on the exhaust??
Old Jun 21, 2011 | 09:05 PM
senix's Avatar
senix
Here is the link to what I was referring to. Kind of don't think it is your concern based upon your discription...
http://www-odi.nhtsa.dot.gov/acms/do...34712-9576.pdf
Old Jun 21, 2011 | 09:40 PM
trnbbcrds2's Avatar
trnbbcrds2
The RH inlet pipe from exhaust manifold to turbo inlet is usually the pipe that cracks where flex tubing is located causing bulk head to become discolored with exhaust soot. The precedure to replace this pipe is to remove cab from frame or remove trans but if bolt was to round off its a difficult time to remove due to tight quarters. warranty pays me 6.3hrs to replace RH inlet pipe, figure cp to range from 8 to 10hrs labor.
Old Jun 21, 2011 | 10:16 PM
Texas450's Avatar
Texas450
thanks for your input ....what causes it to crack?
Old Jun 21, 2011 | 10:54 PM
trnbbcrds2's Avatar
trnbbcrds2
Repetative expansion of inlet pipe at flex fiiting causes it to crack over time. For example if you were to take a piece of thin aluminum and start bending back and forth it would sooner or later crack and break. Some concept.
Boyd254
Oct 25, 2020 01:28 PM
Justin16
1997 - 2003 F150
Mar 28, 2012 10:40 AM
DemonRace6
59
Mar 23, 2012 11:42 PM
jonboysranger
1983 - 2012 Ranger & B-Series
Jul 27, 2010 07:37 PM
Dukhunt22
Mar 28, 2007 12:06 PM
