has anybody stroked the 351 out to a 427 or other stroking options. what is some drawbacks to stroking the 351. what kind of mileage am i looking at and how many miles can i reasonably get before another teardown
Probably depends on the quality of the machine work, parts, and care that was taken putting said engine together. Not to mention intended use, oil change interval, oil type used, and how hard you are on it. Just like with any other engine....
Fuel consumption is tied directly to engine displacement so you can expect a larger motor to drink more go juice.. all else being equal. There's also no reason to expect a stroked motor to have any shorter life than your average stock motor as long as it's assembled correctly.
when they first started doing the 347 they had issues but that was something like 15years ago. Process' and materials have changed a great deal since then....
This is a lot of cam for a stock motor. You definitely need to step up to a better set of heads to get the most out of it. It probably will not work with speed density either. However, if you stroke it to 393, 408, or 427, and upgrade the heads, that will be a nice cam with the right gearing. But if you're going to spend that kind of money you might as well upgrade to a roller cam.
isnt their a difference in blocks from roller to non roller like their is in the 302. beacuse the motor i will be getting is 351 ho with 47k miles on it so the rebuild wont be till next year but i plan on that cam gt40p heads not sure on the carb size probaly a 650 and a weiand stealth or air gap
i'd go with a cam with less duration if you are worried at all about milage and use as a DD, what is the intended use? I'm going to try the Comp Cam XE264HR-14. Mild duration but with 1.7 rockers lift goes up to .544. No way I'd use them "P" heads on a big stroker. Start at the AFR 185 or the 205's. I've got a set of the WP senior heads here that would work better than the "P"'s. I'm really still in the small block world. A 750 cfm would also be a better choice.
Dave
i mean i would use the "P"s before the rebuild then after i was looking at a set of 200cc or 180cc RHS heads. would a 750 be to much for the 351 before the rebuild i was kinda not hoping to have to buy two different carbs
I didn't realize you were talking about a before and after build. A 750 might be alright, not sure on jetting anything anymore. Sure someone can jump in and help.
Dave
GT40P heads on a 351w will work nicely. Your HO block is probably not set up for a roller cam, so you will need link bar lifters to use the comp cams XE264HR. Or you can get the complete roller lifter setup from the explorer that you get your gt40 or gt40p heads from. You will then need to drill two holes in the block to secure the spider assembly. You will need a retrofit roller cam, also called a small base circle, such as a comp cams XR264RF-HR. This cam and gt40 or gt40p heads will get you more than 300 hp. Keep in mind you may have problems finding affordable headers for the p heads.
The gt40p is a better head due to a relocated spark plug. Of course that is the same reason you will have fitment problems with headers. Ford and Mac make a dedicated header for the p head. All other headers may or may not work, you will have to test fit them individually. The Gt40 will accept any header and is still a good head. Keep in mind also that unless your heads were previously on a 351w, the bolt holes will need to be drilled from 7/16" to 1/2".
