Sponsored by: Auxito
trouble shooting AC
Old Jun 14, 2011 | 09:44 PM
MPohl's Avatar
MPohl
trouble shooting AC
Help
I have a 1999 F150 Reg Cab long box 4.6 V8 Auto I am having trouble with the Ac unit. I had the system evaced. last fall and recharged. this spring I went to use the AC and it would not kick in. I had the charge checked out and it was OK still will not kick in. It did kick in for a in yesterday and blew cold. but would not kick in after I turned it off and back on. Where do I start???
Old Jun 15, 2011 | 06:21 AM
projectSHO89's Avatar
projectSHO89
Go to the HVAC section and read the FAQs.
Old Jun 15, 2011 | 09:22 PM
steve(ill)'s Avatar
steve(ill)
check wires on the compressor to see that they are tight. push on the clutch to see if it will engage, maybe the air gap is too big ? There is a low pressure switch that might be failed open and not make contact. jumper it to see if compressor starts.
Old Jun 15, 2011 | 09:48 PM
backntyme55's Avatar
backntyme55
if you own a volt meter , unplug the single wire going to your compressor and check to see if you have 12v to ground or to neg battery terminal when you turn it on, key on without starting it should do, if you have 12volts dc going to the compressor then its right there in your clutch. if not work backward, you can jump the low pressure switch that is usually found on the accumulator tank close to the firewall with a paperclip in the plug for a minute. back up and check to see if you have a blown fuse or under rated at the panel too.
walksLikeBear
1983 - 2012 Ranger & B-Series
Jul 25, 2015 02:24 PM
bartamos
1997 - 2003 F150
Jan 6, 2015 04:14 PM
renchr56
Jan 13, 2014 01:52 PM
bass-n-fire
21
Jul 27, 2011 06:06 PM
