car dolly
Old Jun 9, 2011 | 10:14 PM
t.duggan.photo's Avatar
t.duggan.photo
car dolly
Anyone have experience with these? how much weight on average would they hold?
my friend needs her 98 4 cylinder ranger towed about 400 miles.
To lighten the weight I was thinking about trying to use one of them instead of a trailer. also do they run with a 4 pin trailer brake connector or a 7?
Old Jun 9, 2011 | 11:05 PM
snakedoc's Avatar
snakedoc
all that i have seen are 4 pin. i dont know how much weight you will cut but to me a dolly is the worst way to tow a car. i have had some bad times with the so i wont use them just my .02
Old Jun 10, 2011 | 01:18 AM
Roadfind's Avatar
Roadfind
I would agree with SnakeDoc , those car dollies are fine for short hauls in town or getting stalled car off the hiway . The increased cost of light car trailer is worth the piece of mind on a long tow . Sure you could haul it on th dolly, your truck would do fine . But is it worth doing it for a little less cost ,,,,,,, olllllo
Old Jun 10, 2011 | 07:30 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Car dollies have been around for years and years; motor homes have been using them for long hauls for years. Most use the 4 pin connector for lights and some of the heavier duty ones have surge brakes. You can even buy them now that will hold two motor cycles and a car, they are called heavy haulers. A friend of ours hauled a Ranger PU and two HD cycles on his behind his motor home. If you are looking at the Uhaul type dolly they are built heavy enough to haul a full size PU so a Ranger would be no problem, but remember you can't back up with one.
Denny
Old Jun 10, 2011 | 08:14 AM
dchamberlain's Avatar
dchamberlain
I've towed with the U-Haul car dollies a bunch of times. None of the ones I used had brakes, but depending on the tow vehicle you probably don't need them. They are a LOT lighter than the car trailer.
They are very easy to use and purpose built for the job. But, as has been mentioned, they are hard to back up in.
U-Haul car trailers are also sweet outfits. Purpose built for hauling cars with ramps and wheel tie downs and everything. Pretty much idiot proof. They use surge brakes. I've towed quite a few of those also and are necessary if your vehicle can't be towed with any wheels down.
If your friends Ranger is 4WD, make sure it's safe to tow with any wheels down if you're going to use the dolly, or you remove the right drive shaft.
Old Jun 10, 2011 | 11:40 AM
senix's Avatar
senix
You can use a dolly with the Ranger...gonna have to make sure the steering wheel is secure as the rear is what needs to go on the dollly.
They are all 4-pin.
Given the choice I'd rather use a trailer but I have no problem using a dolly. Even long distance. It is not an issue.
Old Sep 9, 2015 | 11:57 PM
artieb's Avatar
artieb
Landgrebe Mfg. Inc.
I have the TD-40 101
Does well on long hauls
Old Sep 10, 2015 | 05:55 AM
RV_Tech's Avatar
RV_Tech
Towed often with dollies behind motor homes and have owned my own tow dollie. Never a problem. As noted, check the owner's manual for the Ranger regarding towability.
You can back one up, but only for a very short distance and you must have all the wheels in a straight line before you do. I also have done that a number of times. If the wheels are turned, it is possible to roll the tires off the rims.
Steve
renyren
All Things Towing
34
Jan 8, 2017 01:07 AM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Dec 19, 2016 03:26 PM
pikapp
2015 - 2020 F150
15
Feb 18, 2016 04:50 PM
93-331-29PSI
6.7L Power Stroke Diesel
Dec 10, 2015 12:04 PM
clearnetedm
Sep 14, 2009 06:19 AM
