GVWR
Old Feb 10, 2016 | 12:19 PM
pikapp's Avatar
pikapp
GVWR
When calculating GVWR, does that include the tongue weight of the trailer being towed?
Old Feb 10, 2016 | 01:56 PM
JKBrad's Avatar
JKBrad
Yes it does. Any weight that the truck has to bear.
Old Feb 10, 2016 | 02:12 PM
pikapp's Avatar
pikapp
Thanks, was afraid it did.
Old Feb 10, 2016 | 04:16 PM
Frantz's Avatar
Frantz
It includes the liquid in your bladder and the fuel in the tank, and the dirt in the tire tread. Everything that can be weighed on the scale.
Old Feb 11, 2016 | 10:44 AM
pikapp's Avatar
pikapp
Guess I better check the door jamb spec plate, be sure I know what I think the trucks GVWR is. 2015 Spec info. tells me its 7000 #. If so, I'm close to it at 6600.
Old Feb 11, 2016 | 01:08 PM
Frantz's Avatar
Frantz
Most people who haven't made it a habit to concern themselves with it would be surprised to see how close or over they are. So long as you're under you're completely okay and shouldn't think twice. The F150 completely blows away the competition on payload specs currently, but the weight adds up very quickly.
Old Feb 11, 2016 | 01:20 PM
brokenleg's Avatar
brokenleg
what is the GVWR when you have the towing package?
Old Feb 11, 2016 | 05:12 PM
pikapp's Avatar
pikapp
Ain't that the truth. With Curb Wt. of 4925 and GVWR of 7000, doesn't leave much, especially when you add in tongue weight. But as you stated, as long as I'm under, all is good. Thanks
Old Feb 11, 2016 | 07:01 PM
Tom's Avatar
Tom
Doesn't leave much?
That's more than any half-ton truck I've ever heard of. The only exception to that would be the HD models, which used to be referred to as F250s back when they were created in '97.
I don't concern myself much with GVWR. Staying under GAWR means quite a bit more to me, as those are typically based on actual mechanical limitations.
Old Feb 15, 2016 | 09:44 AM
GlueGuy's Avatar
GlueGuy
Dirt in the tire tread is "unsprung weight", and I don't believe it has anything to do with the truck's actual load. Likewise, the weight of the tires & wheels are not actual load on the suspension.
But those things are difficult to subtract out, so get lost as rounding errors.
Old Feb 15, 2016 | 10:09 AM
pikapp's Avatar
pikapp
Originally Posted by Tom
Doesn't leave much?
Yea, I guess what's left over after Curb wt., tongue weight and cargo, is a little better than "not much". I just don't like being to close to max weight allowances, especially when towing is involved. That's why I traded in the Expy and got the 150..went from 9K to 12K...much more room to play with.
Question: Why is the GVWR less than the combined GAWR's, 7250 vs. 7000? I can see why the GAWR is better to watch vs. GVWR. My Rear GAWR is 3800. Minus the 1K tongue wt. that does leave quite a bit for 'other".
Old Feb 15, 2016 | 11:35 AM
Tom's Avatar
Tom
I've never gotten a good answer on that. My best guess is to keep the truck in the right weight class for registration, insurance, and competitive purposes. It wouldn't do to have an F150 with more payload than an F250, after all.
The GAWR is the lowest of the springs, axles, wheels, brakes, wheels, and tires. I've gone over GAWR without issue after addressing the limiting factor, which is usually springs.
Old Feb 15, 2016 | 07:11 PM
onug's Avatar
onug
I did a fair amount of research on this a few years ago when I was hauling a 9,000 trailer. I've never understood why the combination of the GAWR doesn't equal the GVWR either. Even if there's a good "engineering" reason, adding that kind of confusion to something that most people won't research at all doesn't help.
I treat the tires, wheels and axle/leaf springs as separate systems. The tires and wheels have their own rating and the axle/leaf springs are the GAWR. But in general, you will have part fatigue when exceeding them, possibly immediate and catastrophic (thinking tires mainly). Side Humor: GM was given a lot of heck years ago when they were shipping under rated tires on their 2500/3500 trucks. Classic.
I think pickuptrucks.com did a big publication on this years ago. GVWR is more about driving experience and longevity of the truck parts. GCWR is what's really important, as that's when safety becomes compromised. GAWR seems to fit in between both of these.
Prop's to the OP for asking the questions. It's amazing how many people see "tows 12,000lbs" on TV and then buy a trailer that weighs 12,000lbs dry. I've got a neighbor that tows his 26' toy hauler trailer with a Raptor already weighed down with way too many accessories.
Old Feb 16, 2016 | 04:02 PM
pikapp's Avatar
pikapp
Too many times I think I overthink stuff like this. Trying to get everything exactly right. Was obsessed with the tongue weight, got that right, now obsessed over GVWR, making sure I don't overload anything.
Old Feb 16, 2016 | 04:50 PM
Tom's Avatar
Tom
I worry about overloading the tires, hitch, springs, and the axle. I don't worry about overloading the sticker on the door, but some do, as it's technically the correct answer.
