Exterior lights: Problem solved
Old Jun 8, 2011 | 05:55 PM
Irving's Avatar
Irving
On my 2011 F150 XL, to keep ALL the exterior lights (except headlights) from coming on each time a door is opened, the answer is to get your Ford dealer to use their computer to install or change to the POLICE DARK MODE. It also keeps the interior dome light from going on and off when a door is opened or closed, but you can still work the dome light manually. I had this done at no charge and was told it was a "factory alternative" to the default setting, which I called "Christmas tree mode".
Old Jun 8, 2011 | 11:25 PM
Jus2shy's Avatar
Jus2shy
That's pretty sweet, maybe this should be stickied on the board since this question seems to come up a lot.
Old Jun 9, 2011 | 01:03 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
This is a great example of how Ford looks at what the consumers need by looking at what they do post-factory and then integrate that into a factory option.
In most police cars you will find a black out switch, which disables most lights, including brake lights. Its an aftermarket police upfitter option so they are all different, but you can see how Ford is paying attention.
jatimmons
Jan 13, 2017 08:07 AM
Doubleubar
Feb 24, 2016 06:33 AM
BLACKHAWK_1989
Jan 7, 2016 09:42 PM
FarmingF250
Sep 21, 2015 05:47 PM
DrewF
6.7L Power Stroke Diesel
Jul 14, 2011 09:35 PM
