E-Brake cable
Old Jun 6, 2011 | 10:57 PM
Bonanza35's Avatar
Bonanza35
E-Brake cable
I have e99 CC LB 4x4 and I can't find out how to adjust the cable. I put in new brakes and e-brakes also and the cable is tight. I've traced it back down the frame and there is no place to adjust it. When I push on it, it clicks one time and is very hard. It was this way before I replaced the brakes also. I'd like to get the padel at least in the half way area. Thanks,
Chet
Old Jun 6, 2011 | 11:13 PM
mueckster's Avatar
mueckster
I would back off the adjusters of the e-brake shoes. It seems to be the only point of adjustment in my Ford manual also. Mine is pretty tight too. I never use the e-brake that much with my automatic, but do use it on occasion when working on the truck while in neutral.
Old Jun 6, 2011 | 11:18 PM
snakedoc's Avatar
snakedoc
the adjuster is a pain to get to it is on the bottom of the axle in a hole.
Old Jun 7, 2011 | 10:19 AM
Bonanza35's Avatar
Bonanza35
Matt. if your talking about the star adjuster that adjusts the shoes I've done all that. There has to be some place to loosen the cable in order to install a new cable when it breaks. TO give it slack, I just can't find it. Thanks guys all your input its apprecialted!
Chet
funzjb1
Mar 22, 2011 05:12 AM
JHoffman93
Dec 23, 2009 09:19 PM
pdqford
Jun 17, 2008 07:26 PM
