E-brake
Old Mar 21, 2011 | 11:42 PM
funzjb1's Avatar
funzjb1
E-brake
How do you tighten up the e-brake cable??? They used to have threaded rod on the older ones but there is nothing like that now. This has been going on for awhile, I know it's not the brake shoes or and adjustment. The e-brake goes all the way to floor and even on a slight incline the truck will roll (slowly) the brakes work good. Is the cable just stretched??? is this a common occurrence ???
Old Mar 22, 2011 | 05:12 AM
Copedawg's Avatar
Copedawg
1996 Bronco/F-Series Workshop Manual
Section 06-05:
Brake System, Parking
Section 06-05: Brake System, Parking 1996 Bronco, F-150, F-250, F-350, F-Super Duty Chassis Cab and Motorhome Chassis Vehicles Workshop Manual
ADJUSTMENTS
Parking Brake, Cable-Actuated, Transmission-Mounted, F-Super Duty
Field Adjustment, Foot Actuated Lever
Use this adjustment to correct excessive parking brake control travel.
Place the transmission (7003) in neutral and release the parking brake.
Raise and support the vehicle.
Loosen the parking brake adjusting clevis jam nut several turns. Apply a lubricant such as Ford Penetrating Lubricant E8AZ-19A501-B or equivalent to the adjusting nut, threaded rod and the clevis to ease adjustment.
PIC DID NOT TRANSFER
PLEASE FIND IN ABOVE LINK
Item Part Number Description
1 — Actuating Arm (Part of 2598) In Applied Position
2 352358-S2 Self-Locking Pin
3 — Jam Nut (Part of 2853) Loosened
4 — Cable Lengthening Direction
5 — Cable Shortening Direction
6 76007-S8 Clevis Pin
Remove the self-locking pin and the clevis pin from the adjusting clevis.
Hold lever in applied position.
Screw clevis onto threaded end of the front parking brake cable and conduit (2853) until actuating lever hole and clevis holes line up.
Lengthen the front parking brake cable and conduit approximately 13mm (0.5-inch).
Position clevis over lever. Install clevis pin and self-locking pin.
Rotate driveshaft (4602) to make sure parking brake shoes are not dragging against parking brake drum.
Lower the vehicle.
Test the parking brake operation.
s.squared-39
Aug 2, 2016 11:36 PM
taz6131965
Nov 30, 2015 01:23 PM
ETOWN55
Mar 17, 2014 10:28 PM
White76
Dec 23, 2011 07:57 PM
