E-brake adjustment
Old Jun 17, 2008 | 02:52 PM
pdqford's Avatar
pdqford
E-brake adjustment
I noticed on my (new to me) '02 Navigator that the emergency brake does not hold the vehicle and the e-brake pedal goes nearly to the floor. How do I adjust the e-brake cables to take up the slack?
Old Jun 17, 2008 | 02:55 PM
alloro's Avatar
alloro
You have to go underneath with the back end up on jackstands. At each wheel there is a star adjuster inside that you turn just like drum brakes.
Old Jun 17, 2008 | 04:50 PM
pdqford's Avatar
pdqford
Thank you for that info
And to think I just put the back end back down on the ground after putting fresh RTV under the rear diff cover and installing fresh 75W-140 gear lube in there. (That 9.75" rear is BIG and it took all of 3 quarts!) I didn't see any cable adjusters and never thought to look for the star adjusters. Thanks again!
Old Jun 17, 2008 | 07:26 PM
sbclemens's Avatar
sbclemens
If the 02 is similar to the 98 Expy, you have a front and rear cable. So, if the adjuster is at it's limit, you may have to replace the shoes. I don't think the cables themselves can be adjusted. So if the shoes look ok and the adjuster isn't maxed out, then it may be a stretched cable
wolfrace
Sep 24, 2020 07:27 PM
bigunit54
2004 - 2008 F150
Aug 3, 2011 05:23 AM
funzjb1
Mar 22, 2011 05:12 AM
03_PSD
Mar 31, 2009 10:49 AM
vwgtivr
Feb 17, 2009 10:46 PM
