Sponsored by: Real Truck
Warped rotors again
Old Jun 8, 2011 | 11:00 AM
  #46
cartmanea's Avatar
cartmanea
Beechkid, after your last post, I'm guessing your "college degrees" didn't involve upper level physics or thermodynamics classes. You mentioned degrees (multiple?) without listing them, what are they? WyoTech doesn't count...
Old Jun 8, 2011 | 11:08 AM
  #47
F250CCowner's Avatar
F250CCowner
I would think if warping rotors were that much of an issue that sever duty vehicles would demand something that wouldn't warp as easily or as quickly as some of you state. I get what beechkid is saying that these heavy duty units don't need it what should our relatively light (by comparison) superduty need them. I'm not buying the snake oil or the kool aid either. I have a 03' CC with a 5.4 and tow a 9800 lbs trailer up and down big bear/up the cajon pass on a now regular basis and these rotors have 60K on them and are doing fine. So i don't know maybe I got a something different then you guys did. But my ***** is holding up fine.
Old Jun 8, 2011 | 12:08 PM
  #48
dkf's Avatar
dkf
Do some welding and repair work on various metals (including cast iron) and you'll see how heat can distort metals. Same goes for the machining end.
Old Jun 8, 2011 | 12:35 PM
  #49
Bdox's Avatar
Bdox
Yet another good driver!
Old Jun 8, 2011 | 12:37 PM
  #50
Bdox's Avatar
Bdox
Originally Posted by PA74F250
Some peoples kids....
You are soooo right! I'd hate to be stuck sitting next to him on a full flight.
Old Jun 8, 2011 | 12:54 PM
  #51
wizardsr's Avatar
wizardsr
On a superduty, you really don't need slotted or cross drilled rotors, unless you drive it like ya stole it on a regular basis. I've had pretty good luck on all of mine, other than rusting issues from sitting, but I can't say I've ever warped a rotor on a super duty. Now my 90 and 96 chevies were a different story. Before switching to cross drilled rotors on those, warpage and brake fade were a major issue. I was turning rotors every 5k miles (lots of in-town stop and go) and replacing the rotors and pads every 10k. The brakes were too dang small, and the rotors way too thin on those trucks right from the factory. After the fuel pump went on the 90 and the rear end blew apart on the 96 in the same day, along with all the brake and transmission issues, I bought a 2000 F350 and never looked back!
Old Jun 8, 2011 | 01:07 PM
  #52
cartmanea's Avatar
cartmanea
Agreed, they really don't have a warping issue if you know what you're doing. We've grossed over 30k several times driving over the mountain in eastern Oregon in my dad's '03 and never had any braking issues, now at 70k still on all the original pads and rotors. One rotor is feeling warped now, but that didn't happen until 65k, under extended warranty, the Ford dealership did ball joints and the gorilla doing the work hammered the wheels back on with the impact wrench unevenly. We always rotate our own tires and properly torque them; one time from this idiot and they warped within a few days... Torque them on evenly, and you won't have any issues. Tighten them unevenly, and it doesn't take much heat to warp them. Happens to any vehicle, not just heavy ones. The local tire store warped the rotors on my old Dodge Intrepid when I got new tires, and I threw a fit until I got them to pay for new rotors and pads (I did the work, didn't want them touching it after that).
Old Jun 8, 2011 | 01:14 PM
  #53
F250CCowner
Welding is TOTALLY different than a part being used in its regular duty cycle.
Old Jun 8, 2011 | 01:55 PM
  #54
cartmanea's Avatar
cartmanea
Agreed, welding involves dissimilar metals with different cooling rates.
Old Jun 8, 2011 | 02:01 PM
  #55
cablemanF250's Avatar
cablemanF250
I wish i would have kept my last set of front rotor's, laying flat on the ground you could see the warp-age, even the Ford dealer said they had warped. I've learned over the years, whats on paper is different then what happens in the real world.
Old Jun 29, 2011 | 09:05 AM
  #56
gwh1bass's Avatar
gwh1bass
The rotors on my Ex need to be machined every 10,000+ miles until there isn't enough material left and then replaced.
Old Jun 29, 2011 | 10:26 AM
  #57
dkf's Avatar
dkf
Production welding new metals yes. Repair/welding the same pieces off the production floor multiple times over many decades of use, no. Some of the stuff we repaired required being baked for a day before work could even begin. Some of the parts were 100 years old and still being used in production.
KJNDIVER
37
Aug 19, 2020 11:24 PM
Big Sky
Jun 2, 2016 09:42 PM
Flawless_X
Oct 2, 2010 11:19 AM
deercreek1
Mar 23, 2009 08:53 AM
BrianA
Jun 24, 2006 12:29 PM
