Inline 240, 66 F100, Carb perculating!!!!
Old Jun 3, 2011 | 12:52 PM
pwillis44's Avatar
pwillis44
Hello all,
Long time no post for me. Hope all are well. Got an issue that sprung up after 5 years of owning my 66 F100.
It is summer here in Music City, TN and it gets hot. I just had a spacer made for my carb and I am still perculating (almost to vapor lock) at stop lights or going over speed bumps at slow speeds. Anyone else ever had the same problem? And if so what did you do?
I tried wood close pins on the steel fuel line, replaced the steel fuel line with rubber gas line, this year added an aluminum 1/4" spacer and I still have no luck with stalling or the truck wanting to shut off.
When it is cool or cold out truck runs like a champ. no spudder no stalls nothing. All in the same places the truck would stall or spudder in the summer.
I am thinking or adding a hose to the oil bath beather to the radiator support to grab some cool air??? or replacing that with an air filter type and runnning the hose in the same manner. Any suggestions? My truck is a daily driver and I am about to add air conditioning so I can use any help. Thanks Phillip
Old Jun 3, 2011 | 01:03 PM
shortwide's Avatar
shortwide
What engine temps are you running?
Old Jun 3, 2011 | 09:27 PM
cdherman's Avatar
cdherman
Check the heat riser diverter on the exhaust manifold. Its probably stuck open.....
Or, its just really hot!! My 1101 and Carter YF both will percolate when its over 100 degrees. Kind of nasty!!!
It did that in 65 too, according to dad. Damn thing would vapor lock in the heat of summer from day ONE!!
Old Jun 6, 2011 | 10:20 AM
pwillis44's Avatar
pwillis44
Runs 170 all summer.
Old Jun 6, 2011 | 10:21 AM
pwillis44's Avatar
pwillis44
I just replaced it in October. It is rattling noticied the rattle last week. Gonna check that out. Thanks
Old Jun 6, 2011 | 10:33 AM
rustywheel68's Avatar
rustywheel68
if the heat riser isn't the problem- pull out that aluminum spacer and go with a phenolic one...less heat transfer.
Old Jun 7, 2011 | 01:44 PM
pwillis44's Avatar
pwillis44
Where is the best place to find a phenolic type or the material. Thanks
Old Jun 7, 2011 | 02:30 PM
rustywheel68
hmm...i can't find one for a 1bbl carb.
here's one that would be heated/cooled by the coolant flow.
Mustang Parts from Mustangs Plus :: Engine :: Carburetor Spacers :: 1965-68 170/200 1 Bbl Carburetor Spacer
i haven't done it myself (yet), but a lot of people run coolant to the bottom of the intake manifold after converting to the EFI exhaust manifolds (since they have no heat riser).
Old Jun 8, 2011 | 09:50 AM
pwillis44's Avatar
pwillis44
Thanks for the tip. I am still wondering if I can cool it with air directly to the oil bath...
Old Oct 14, 2024 | 12:48 PM
Henryetta66f100's Avatar
Henryetta66f100
1st Gear
Same problem
what did you find out?
Old Oct 15, 2024 | 04:27 AM
Crop Duster's Avatar
Crop Duster
The person you are asking hasn't logged in since 2011. You might want to start your own thread either here or in the engine forum. Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums (ford-trucks.com)
hooler1
Aug 2, 2017 04:38 AM
The crazy Dane
16
Jan 19, 2017 10:30 AM
jesse zondlo
Dec 14, 2016 03:12 PM
Pierre Comeau
Nov 27, 2015 08:31 PM
watts127
2004 - 2008 F150
17
Apr 12, 2012 07:06 PM
