Hi all, I have a 92 f150 5.8
Have not had any problems other than the check engine light, put her on a scanner and keep getting a 332 code (insufficient EGR flow)
Anyway was checking the A/C yester day and removed the wires going to the A/C compressor. All of a sudden the truck idles high. Did not tug or mess with any other wires, did not mess with anything else, what in the heck happened and where should I begin checking? I put the scanner on it again and still just get the 332 code, nothing else.
what happened when you hooked the wires back to the ac compressor?
you may have a vacum leak at the EGR. get a vacum pump and test your egr. your haynes manual should have instructions. also check out Ford Fuel Injection.
has the idle screw on the throttle body been messed with?
A/C compressor--nothing happened and thats problem number 14.
OK on the check for vacuum leak. I did spray starter fluid around and did not get a raise out of hte idle but I know thats a hillbilly way of doing things, but I am thoroughbred hillbilly so.....
As far as I know the idle screw has not been messed with.
Thanks for the link I will check it out.
Took the truck to the local exhaust joint, they fixed a y pipe leak and fixed the EGR to exhaust pipe.
Idle remains variable, sometimes high, sometimes normal. Cannot still quite figure it out. Maybe need a new EGR valve?
Any further help would be greatly appreciated.
Thanks
Robb
