Running problems after cleaning
Old Jun 9, 2011 | 01:28 PM
82 IBronco5.0's Avatar
82 IBronco5.0
Ok I have an 82 full size bronco.. I went muddin and got the motor nasty.. Well I went a month without cleaning it and it ran perfect! Now that I decided to hose it down while running it wants to act crazy idle is pretty good but accelerating it's spits and sputters through the carb and exaust.. I have a MSD ignition system on it a 6AL to be exact I have the MSD coil, distributer, and spark distribution box.. I took the cap off the distributer and there was excessive moisture in it.. Could that be the problem? I'm Letting it dry now
Old Jun 9, 2011 | 01:31 PM
BVR PLZR's Avatar
BVR PLZR
i would venture to bet if you spray some brake clean in there wipe it out and leave the cap off awile you will have your solution
Old Jun 9, 2011 | 01:41 PM
82 IBronco5.0
Well I just sprayed a lil carb cleaner in it and letting it dry a lil more
Old Jun 9, 2011 | 01:44 PM
BVR PLZR's Avatar
BVR PLZR
if you have a filter on your air hose you can speed up the process if not you will take the risk of adding moisture
Old Jun 9, 2011 | 01:54 PM
82 IBronco5.0
I actually don't have a compresser but it should be dry by now it's 95 degrees out there so ima see what she'll do I'll be back
Old Jun 9, 2011 | 02:05 PM
82 IBronco5.0
Ok hey thanks bro for the spray cleaner tip!!! Runs like a dream again!!! Threw the cap back on and took it up the mountain and she runs perfect!!!
Old Jun 9, 2011 | 02:07 PM
BVR PLZR's Avatar
BVR PLZR
Glad to hear, Can of Brake Clean and a Can of LIquid wrench never leave my side LOL
Barkin 40s
47
Aug 19, 2010 07:01 PM
gtex
16
Nov 4, 2005 02:55 AM
79_custom
47
May 18, 2004 04:57 PM
mshumack
Oct 18, 2002 08:02 PM
slikness
22
Jan 1, 2001 11:12 PM
