Hi,
I'm getting a code 332 which is indicates no egr flow.
DPFE sensor checks out ok.
EGR solenoid checks out ok.
EGR valve appears to work (if you apply vacuum when engine is idling, it will idle rough)
All hoses seem to be ok.
Oxygen sensor seems ok... How would that cause a 332 code?
All of the EGR tube is clear... to include where it goes into the manifold. When I apply a vacuum to the EGR valve... the engine will run rough at idle... which is what it should do.
