Brake Rotors-Type
Old Jun 2, 2011 | 11:20 AM
SNIPER168308's Avatar
SNIPER168308
Brake Rotors-Type
My front rotors are warped again. I'm tired of this, so I'm looking at replacing them with a pair of slotted or slotted/drilled. Does anyone have any suggestions as to which type is better? Advantages? Brand? and where to purchase for best price? Can I run a set of these on the front without changing the stock rear rotors? Thanks...
Old Jun 2, 2011 | 11:22 AM
nlemerise's Avatar
nlemerise
Clay can help you out at RiffRaff Diesel.
Old Jun 2, 2011 | 11:25 AM
texans's Avatar
texans
I hear alot of people talking about ART rotors. Here is a link to there site. Applied Rotor Technology
Old Jun 2, 2011 | 11:35 AM
clintbonnie's Avatar
clintbonnie
I have had good luck with Brake Pads | Brake Rotors | Slotted Rotors - Power Stop Brakes with their slotted rotors and their ceramic pads.. After 3 years, the rotors look like new with no warpage.. (don't think drilled rotors are recommended for heavy duty use).
One thing that I think helps to prevent warpage it to creep forward 10 or 20 feet after stopping to allow the heat to dissipate over the entire rotor evenly, especially if the brakes are hot.
Old Jun 2, 2011 | 11:36 AM
riverrat41's Avatar
riverrat41
I like the Powerslot's with the Hawk Super Duty pads.
You can just replace the fronts.Fronts take most of the rough treatment.
Old Jun 2, 2011 | 12:54 PM
SNIPER168308
What about the dimple drilled instead of cross drilled? clintbonnie, you mentioned not using drilled rotors for HD use.. anyone have a definite answer on that?
Old Jun 2, 2011 | 01:46 PM
clintbonnie
Not sure about dimpling.. but heres what powerstop says about slotted rotors and heavy duty use such as towing.. IMO, drilled holes add additional surfaces for which cracks can occur.
Product Description
PowerStop Slotted Brake Rotors provides a nice cleaning action to wipe away friction debris. Friction dust and gas gets sandwiched between the pad and the rotor, and this can reduce pad bite. Independent tests show that slotted rotors do not improve the brake performance as much as drilled rotors, but they are structurally stronger to handle severe thermal shock. Power Stop recommends our Slotted Brake Rotors for racing, and heavy duty applications like hauling, towing, and fleet use. The silver zinc dichromate finish is highly resistant to corrosion
Old Jun 2, 2011 | 06:41 PM
SNIPER168308
Thanks for the info.. will be researching this a bit more before I decide which is best...
Old Jun 2, 2011 | 06:54 PM
UP_There's Avatar
UP_There
Powerslot cryo treated rotors, with Hawk pads is what I run.......they work GREAT, and you won't have to replace your brakes every 20,000 miles due to warped rotors
Old Jun 2, 2011 | 07:02 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
I run ART and I love them. Complete the circle with stainless braided brake lines and you think youre stopping a sports car instead of a huge truck. An amazing difference......
Old Jun 2, 2011 | 07:52 PM
SkySkiJason's Avatar
SkySkiJason
What brake pads are you using?
Cryoed, dimpled, slotted and otherwise molested rotors are a waste of money.
I recommend lifetime warranty rotors from Oriellys and EBC brake pads from Clay. Good pads ARE worth the money...
Old Jun 2, 2011 | 09:16 PM
UP_There's Avatar
UP_There
I'll have to disagree on that statement. I tried both Motorcraft OEM Rotors, and top of the line from Napa. Both warped. The Powerslot cryo treated rotors are pricey yes....but well worth it, and they stop GREAT paired with Hawk Pads, huge difference over stock pads/rotors
Old Jun 2, 2011 | 09:44 PM
SkySkiJason
I did say GOOD PADS... This is waaaay more important than than the rotor. FWIW, the 2-piece rotors should be more resistant to warping - but since it only adds 5min to change a rotor when doing tire rotation - I'll just pick up a new (free) rotor or 2 every 80-100k miles...
Anyway, here's some good reading for those who still have an open mind. Lol.
https://www.ford-trucks.com/forums/1...l#post10068760
DISLFVR
Oct 15, 2012 09:12 PM
f150700
2004 - 2008 F150
Jan 26, 2012 06:53 PM
ranstl
2004 - 2008 F150
Oct 30, 2010 09:02 AM
RudyF6
May 24, 2006 05:56 PM
Twissted
Mar 21, 2005 02:51 PM
